Re: 4L80E behind a 5.3
Does the 67-72 cab need a high hump for the 4L80e to fit? And is there anything that need to change on the 5.3 so the 4l80e will work except from the pcm flash and wire harness mod?
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059 Front/back Porterbuilt dropmember, Accuair, LS1/4L60e Chevrolet C20 -72 C20 to K10/20 conversion, LS power. |
Yes you will need to have a high hump. If you are layed out you will have to make a few additional mods to the hump and floor. As for the swap you will also have to figure out what converter you are running. If you plan to run a stock 80 you will need the flex plate and spacer from the 6.0l. If you are going to a custom converter you can have the cover done so you can use the stock 60e stuff.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
It may depend on where the engine is mounted, but my blue 72 had a 6.0/4l80e and had the low hump and it fit fine. There are pics in the build thread in my sig if you want to see where the engine was, but it was close enough to stock that the fan fit the fan shroud.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#4 | |
On a side note yours and acks trucks were the ones that pushed me to an LS in mine. Loved how clean it was! Have you seen it since it sold at auction?
