Old 10-20-2015, 04:22 PM   #7
1970pelle
1970pelle's Avatar
Re: Drop spring hanger help
If you do decide to go with these brackets. Following the advice already given, I would go one step further and use a larger bolt in the affected holes.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
lowering kit, springs
