04-06-2012, 10:45 AM | #76 |
Re: 1960-66 parts from big stash
What do you have in the area of hubcaps? Condition isn't particularly important as long as they aren't completely rusted through. I'm interested in '64-'66 caps.
04-07-2012, 10:35 AM | #77 |
Looking for a right side door for a 60-63. How much with shiping with grayhound?
10-26-2015, 04:19 AM | #78 | |
I need a Mount for my wiper Motor like this. Do you have some one like this ??? Thank you verry much. Greetings Nils |
10-26-2015, 04:42 PM | #79 |
Hi,
Looking for short bedside for drivers side. Would also be interested in a good hood for my 65. r/Moe |
10-26-2015, 08:06 PM | #80 |
Nils, I believe I have a junk cab we could possibly cut that area out of and get you the spot-welded wiper motor flange you need. Do you have rotted sheetmetal around yours? if so we can maybe cut it out bigger than needed to give you something to work with....
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
10-26-2015, 08:08 PM | #81 |
No bedsides presently Moe, but I will put you second in line behind another guy who called yesterday wanting the only hood I have left. If he passes, I will contact you
10-28-2015, 08:18 PM | #82 |
Hi, I need a nice looking radio antenna for a 66 c10 and I also would like a key lock cylinder for a door. I do not need a key, will get it rekeyed. Thanks
10-29-2015, 04:47 PM | #83 |
Do you have any 63-66 chevy/gmc painted front bumper guards? Thanks.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-31-2015, 07:23 PM | #84 |
PM sent GMCNUT.
11-01-2015, 07:08 AM | #85 |
How about an automatic transmission steering column for a '66 GMC? Don't need the wheel. Just the column.
11-02-2015, 01:53 PM | #86 |
Hey,
got any 60-63 passenger side doors? |
03-10-2017, 01:20 AM | #87 |
Any chance do you you have a 60 draglink ? Mine got bent in a wreck . Thanks
04-26-2017, 09:18 PM | #88 |
Looking for a part for my 1964 c10 steering column, believe it is the mast jacket. Originally 3 on tree, previous owner moved shifter to floor and gutted the column. Currently my blinker housing does not attach to anything on the lower part of the column and will just rotate around on the column. The blinker housing does sit in the shifter housing. The piece I have looks to have been sawed on or broken off where the blinker housing would slide over (the bottom slats) to secure it.
Thanks in advance, - Duane |
04-27-2017, 08:39 PM | #89 | |
05-01-2017, 02:08 PM | #90 |
Wouldent happen to have one of these would you? |
05-02-2017, 02:14 AM | #91 |
pretty sure I already sold the NOS 4 speed backup switch and pawl I had, but will check
05-02-2017, 02:17 AM | #92 |
Thanks. Jim
05-02-2017, 02:21 AM | #93 |
05-02-2017, 03:00 AM | #94 |
Any 1960 Chevy hubcaps? need all 4
11-19-2017, 05:17 AM | #95 |
Hi, do you have all the components for the park brake on a 65? I have cables and the inside cab lever but need the cross member assembly and the components in the rear wheels.
Regards, David |
12-15-2017, 10:56 PM | #96 |
Active Member
Do you have an oil bath air cleaner for 60 283 V8 2bbl without PCV? Thanks!
Submariner616 1965 Chevrolet K20 350 4 speed manual |
12-16-2017, 08:43 AM | #97 |
GM outer rocker panels for 63?
12-17-2017, 01:33 PM | #98 |
sorry seeing this so late, but I think I have one - 200 bucks if still looking
12-17-2017, 01:35 PM | #99 |
GM NOS rockers come up on ebay fairly often and range in price; I have bought and installed both reproduction and NOS and personally don't see a value in GM part numbers pieces over nice Tri-plus ones - Tri plus is actually heavier guage metal to boot. Hire a good body man and get him some Tri-plus parts and you won't be disappointed.
12-17-2017, 01:43 PM | #100 |
I may actually have all that on a 63 frame I am going to have to move and crush soon. When I retrieve it I will see if all that stuff is on it and remove for you but you'll have to be patient because at the moment I am not entirely certain when that frame will get moved yet. I am in-process of moving a bunch of crap from a distant site to a more nearby one
