30 ohms on the sending unit for 65?
Sorry if this question is silly - on eBay there are GM sending units for 64 and older that are 0-30 ohms but the same company has 65+ as 0-90 ohms? I think my 65 is still a 0-30 ohms...any input?
Re: 30 ohms on the sending unit for 65?
should be 0-30 somebody else will chime in. I bought a new cheap one $29, and it didn't go to full, only about 3/4. Have seen them for $49 don't know if there is any difference. put my old one back in and it works fine.
1961 chevy K10 my build is------------61K10 build |
![]() Join Date: Mar 2013
I got my sending unit from Truck and Car shop and it worked fine. Worked so fine that when I went over bumps the gas that caused the sending unit to move up and down moved the gauge with it. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
It's Better With Nitro
Yes, if you still have the factory gas tank behind the seat and the original fuel level gauge, you will need the 0-30 ohm sending unit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#5 | |
Wouldn't you need a 0-30 ohm unit no matter what tank you have (in-cab, rear frame mount,...) as long as your using the stock gauge?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
The big thing is to match the sending unit with your gauge. If you have OEM gauges for your model, it should be 0-30ohm. Aftermarket can be 0-30ohm, 0-90ohm,204-33ohm, ect.
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
Awesome - thanks guys. I have the stock gauge but I need to shorten the rod on the stock sending unit because its being installed in a 1996 Cadillac Fleetwood tank. Basically installs like the 69 Camaro tanks in the back, and fills under the tag, but is poly so it works with my diesel and no risk of rust in the fuel system. Right now its just mocked up with some ratchet straps until I get the wiring and suction/return setup.
#8 | ||
I've been real careful with that sending unit - I won't move it around too harsh.
