Old 11-08-2015, 05:44 PM   #1
chrismoore701
chrismoore701's Avatar
Firewall pad
I am finishing my 1979 interior and really do not want to use the firewall pad. I am planning to use a hush mat type of material your thoughts. And I am planning to go around my steering column gas peddle and heater box. Do you guys see any issues with this? Will the carpet cover it. At least from a regular point of view. I don't care if someone stick their head up there and sees it
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 11-09-2015, 09:18 AM   #2
chrismoore701
Re: Firewall pad
I looked at a bunch of interior pics on line and it looks like the carpet will go up high enough to cover the hush mat
Chris
Old 11-09-2015, 12:34 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Firewall pad
The problem I see is Hush Mat is not a thermal barrier. You have no added protection from radiant heat with outhe pad.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-09-2015, 09:53 PM   #4
chrismoore701
Re: Firewall pad
I found some r3 duct insulation at Home Depot. I am going to give this a try. It is just over 1/8" thi k and is both sound and temp deadiner. What do you guys think? I have heard people using this. Plan to put it all the way up the fire wall. The whole floor. The back of the cab and the doors
Chris
Old 11-09-2015, 10:05 PM   #5
enaberif
Re: Firewall pad
Ayr Foil would be a good alternative. Its bubble wrap but withstands heat and would be good for this application.
enaberif is offline   Reply With Quote
Old 11-10-2015, 08:25 AM   #6
chrismoore701
Re: Firewall pad
What do you think about doubling the mat along the fire wall and single layer under the floor? Just to try to break the heat on the fire wall
Chris
Chris
Old 11-11-2015, 12:20 AM   #7
chrismoore701
Re: Firewall pad
Added a second layer. Pretty happy how it turned out
Chris
