Old 11-15-2015, 12:55 AM   #51
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
Finally getting moving along again. I realized I missed a ton of stuff, But i did put it together enough to drive it at graduation and hear the very healthy engine run. Loved how it sounded. More recently I Built a fan shroud for the 16" electric fan because I decided to go that route. I also bent up some tranny cooler lines and got rid of the external cooler for a cleaner look. I blasted the cab and got most of the holes and spot welds smoothed out. I disassembled the entire bed and started getting a game plan figured out. I am going to run a roll pan along with a rear bumper that is nice and tucked in. Full ocd on engine bay to make it as absolutely tidy as I can. All spark plug wires are hidden, and all engine bay wires will be hidden in F6 wire loom which I love the look of. Bent up a solid fuel line. I used header paint and clear on the headers, after a quick porting to open them up to the port on the head. I want to hear any input, or if any of you have ideas on paint because I am constantly torn. Please turn head for viewing pleasure.
1941 Chevy Cabover- Future carhauler build
1949 Chevy Pickup
1955 Chevy Pickup
1959 Apache fleetside
1965 Chevy Pickup- Current Ground up Build
1972 Gmc Pickup- Getting rebuilt engine and 700r4
JP_67_GMC is offline   Reply With Quote
Old 11-15-2015, 01:04 AM   #52
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
More pictures including the header porting, tore down both doors and stripped all the paint off. Filled trim holes, and rust repair. Starting to gear up for bodywork and paint so I see alot of block sanding in my future.
1949 Chevy Pickup
1955 Chevy Pickup
Old 11-15-2015, 03:24 AM   #53
Bomp
Bomp's Avatar
Re: 65' Chevy C10
Cab is looking good.
How are you going to go about doing that door skin?
Bomp is offline   Reply With Quote
Old 11-15-2015, 12:38 PM   #54
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
Door overall is pretty straight, its just the corners that were rusted out. I will just cut out a piece and brake the edges over as far as the brake will allow, then shrink the vertical side and weld them in.
1949 Chevy Pickup
1955 Chevy Pickup
Old 11-15-2015, 03:59 PM   #55
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
So the cut down to swb is happening, I feel like it is a must. I really cant stand the lwb pickups. I need input on if I cut directly under the cab and don't even mess with the suspension, I should be safe correct? I know most people cut further back but I am not sure why that would be nessesary. Thanks for any help.
1949 Chevy Pickup
1955 Chevy Pickup
Old 11-22-2015, 06:52 PM   #56
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
I did some cutting yesterday. No more LWB!! it has been bugging me for a while and finally bit the bullet. Used the plasma to cut, and tigged all back together. Fit up was excellent, how ever laying underneath and running a foot pedal with the underside of my knee wasn't much fun. Within 1/16" of being perfect.
1949 Chevy Pickup
1955 Chevy Pickup
Old 12-06-2015, 10:09 PM   #57
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Thumbs up Re: 65' Chevy C10
Looking good. Nice job on the cut & weld.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 12-08-2015, 11:14 PM   #58
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
Started cutting the heavily mangled bedsides. Pounded out most of the damage before cutting, and set the cut right in the middle of the damage just to get rid of it. Last pic is the side tacked and clamped in one piece. World of difference from being 8 feet long. BTW, right side is just help with clamps that is not final alignment, left side is however permanent. thanks
1949 Chevy Pickup
1955 Chevy Pickup
Old 12-08-2015, 11:20 PM   #59
Bomp
Bomp's Avatar
Re: 65' Chevy C10
I was pounding on a bed side today too. Nice to see Im not the only one.
Yours is looking good.
Old 12-08-2015, 11:35 PM   #60
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
"farm truck," especially coming from our farm is bad. From what my uncles have told me it hit the mail box twice. Once on each bedside of course. And I've found far more dents that they aren't even sure about. OCD says get it laser straight, and from all of your stuff I can tell you are the same way.
1949 Chevy Pickup
1955 Chevy Pickup
Old 01-01-2016, 10:30 PM   #61
JP_67_GMC
JP_67_GMC's Avatar
Re: 65' Chevy C10
Got the frame shortening process completed, welded on the new cab mounts I made, and got it all painted up again. Then I cut down the driveshaft to find out that the crossmember is a little to close for comfort, about 1 inch with no weight on the suspension. I will just modify that some. And I put the cab on to start mocking up everything before starting body work and paint. And for anyone wondering I made sure the driveshaft yoke was clocked perfectly and that the entire thing was true. And will take it to get the balance checked. And a little comparison between my weld and the place that made it.
1949 Chevy Pickup
1955 Chevy Pickup
