Old 03-14-2009, 06:20 PM   #1
SS68
SS68's Avatar
proportioning valve question for disk conv
i have a 70 c10 i bought a performance online disk brake conversion kit and a booster and mastercylinder from autozone to save some money. i bought both a proportioning valve made for disk conversions, and a adjustable valve for the rear lines. problem im having is the proportioning valve i bought haves 5 holes for lines to go in. but i only have 4 lines to plug into it. i pulled this picture from the faqs ive been reading to answer my problem and noticed this small piece on top that i dont have. any help on this? thanks
SS68 is offline   Reply With Quote
Old 03-14-2009, 06:31 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: proportioning valve question for disk conv
on some of the aftermarket prop valves (talking CPP part# PV-1), you will have 2 line connections for the front. you will only use 1 of those. you will need to plug the one you are pointing to in the picture above.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-14-2009, 06:35 PM   #3
SS68
SS68's Avatar
thank you sir, that was my first tought but wanted to make sure, will i be fine if i only run the proportioning valve w/o the adjustable one for the rear brakes?
Old 03-14-2009, 06:45 PM   #4
tcb-1
tcb-1's Avatar
I don't have an adjustable valve on my rears. I never had a problem, but many people will tell you it makes the system much better.
Doug
Old 03-14-2009, 06:48 PM   #5
SS68
SS68's Avatar
right on ill get these installed tomorrow and get the beast back on the road, thanks
Old 03-14-2009, 06:59 PM   #6
spinning wheels
spinning wheels's Avatar
This is my set up on my '72 3/4 ton.....
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-14-2009, 10:21 PM   #7
Andy4639
Old member
Andy4639's Avatar
This is my 71 1/2 ton. The only time I have ever had a issue with the backs locking up is in a emergancy stop in the rain. On dry pavement they have never been a problem.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-14-2009, 10:49 PM   #8
A.P.
Black 72 Chevy
A.P.'s Avatar
Bleeder.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 03-15-2009, 09:47 PM   #9
SS68
SS68's Avatar
one more question, on the bottom of the proportioning valve the line for the front brakes the fitting that goes in there is 1/8 and i can only fit a 1/8" line all the other lines are 1/4" is this the same on yall?
Old 03-15-2009, 10:56 PM   #10
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Wink Re: proportioning valve question for disk conv
That line is 3/16" and the thing in your first pic is a bleeder screw.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-15-2009, 11:21 PM   #11
spinning wheels
Not sure what size the brake line has, it is a stock '72 3/4 ton. The proportioning valve is from CCP. They also sell refurbished stock proportioning valves, but they cost more than their inhouse brand.
Old 03-16-2009, 06:54 PM   #12
Jim Osborne
I also have a question on this subject my truck came with 4 wheel drums . I changed it to 4 wheel disc will the orignal proportioning valve work.
Jim Osborne is offline   Reply With Quote
Old 03-16-2009, 07:22 PM   #13
cdowns
cdowns's Avatar
4wheel drums to 4wheel discs you need to change both the master cyl and the prop valve for proper operation
Old 03-16-2009, 07:23 PM   #14
tcb-1
tcb-1's Avatar
no. you should go with a front disc/rear drum prop valve with an adjustable valve governing the rear. I don't think a specifc disc/disc valve is offered.
Doug
Old 03-16-2009, 07:42 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
You need to buy a 3/16" male-to-1/4" female adapter to screw into the bottom of the porportioning valve. This will allow you to run a 1/4" line down to the "T" on the backside of the front crossmember.
I got mine at the local ACE Hardware store. They are specialty fittings. (Inverted flare adapters)
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 03-16-2009, 07:57 PM   #16
cdowns
cdowns's Avatar
all silverados made in the past 6-7years have 4wheel disc master cyl and proportioning valves thats what i'd be looking at to use for 4wheel disc brakes on a chevy truck
Old 01-07-2016, 09:11 PM   #17
csfields
csfields's Avatar
Purchasing a POL proportioning valve for disc disc. The new one has 3/8-24 thread 3/16 inv for the front and 9/16-18 for the rear. I am running stock lines. Is the adapter mentioned above what I need to make this work?
Thanks for your help
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 01-07-2016, 10:34 PM   #18
davepl
davepl's Avatar
Corvettes of the era offered a disc/disc master, I believe. I don't know what was used in the JL8 Camaros, but I assume the same unit. Parts-store cheap, either way.
Don't forget that on 3/4T the front is the rear line and vice versa, at least as I recall it was backwards from that 1/2 tons.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-07-2016, 10:42 PM   #19
csfields
csfields's Avatar
[QUOTE=davepl;7439153]Corvettes of the era offered a disc/disc master, I believe. I don't know what was used in the JL8 Camaros, but I assume the same unit. Parts-store cheap, either way.
Don't forget that on 3/4T the front is the rear line and vice versa, at least as I recall it was backwards from that 1/2 tons.[/QUOTE
It is a corvette style master cylinder with a pol proportion valve. Just want to make sure I have everything I need when I go to hook it up. Thanks.
