Old 01-12-2016, 07:47 PM   #76
GRX
GRX's Avatar
Re: Starting my engine build
40 over is always interesting. Often indicates the engine was rebuilt twice since 30 is the usual first step. Unless the cylinders were too worn for that the 1st time.
[edit] - looks like christmas all over again. Good to see the bottle of assembly lube along with the new cam.
GRX is offline   Reply With Quote
Old 01-12-2016, 07:48 PM   #77
Mrturner1
I'm also swapping the Edelbrock 600 for a 650 AVS Edelbrock, but we'll see how it goes, might try a Holley 670
Mrturner1 is offline   Reply With Quote
Old 01-12-2016, 07:52 PM   #78
Mrturner1
I'm kinda wondering about the head gasket issue. It was said earlier that a 400 head gasket would be needed instead of replacement 350 SBC gaskets. Haven't bought them yet but I'll need to soon
Old 01-12-2016, 07:54 PM   #79
geezer#99
geezer#99's Avatar
What's the specs on the cam?
geezer#99 is online now   Reply With Quote
Old 01-12-2016, 07:55 PM   #80
GRX
GRX's Avatar
Only difference in the 400 gasket is the steam holes between the cylinders. If you are not running a 400 block, don't worry about it.
Old 01-12-2016, 08:25 PM   #81
Mrturner1
New cam
Old 01-12-2016, 08:28 PM   #82
Mrturner1
I can't get the center nut in the crank pulley loose....grrr busted knuckles
Old 01-12-2016, 09:00 PM   #83
davepl
davepl's Avatar
You can try heating it a little but don't get carried away, the balancer has a rubber ring in the center you don't want to cook.
An impact is always handy there, but you should be able to get it with a breaker bar (or pipe on a sturdy socket driver) if you can keep the engine from turning instead. I've done that wedging a screwdriver in the flexplate holes, but I'm sure there's a better way someone will have to offer.
You can also use a short piece of pipe or something and give it a whack. I forget the technical term, but even hitting it head on can sometimes "break" the thread lock.
If you can get PB (liquid wrench) in there, the longer it can soak the better. Like overnight, or days.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-12-2016, 09:05 PM   #84
Mrturner1
Thanks Dave that puppy came right off. On to the timing cover now
Old 01-12-2016, 09:17 PM   #85
Mrturner1
Got the timing cover off and found this, is this a double roller? Because if so I'll just return the one I bought today
Old 01-12-2016, 09:26 PM   #86
geezer#99
geezer#99's Avatar
Turf that old double roller.
Put the new one in.
Cheap insurance.
Old 01-12-2016, 09:42 PM   #87
davepl
davepl's Avatar
Can I ask how? I suggested a couple of things, curious as to which one worked so I know next time!
Old 01-12-2016, 09:59 PM   #88
Mrturner1
Big screw driver in the flex plate worked great
Old 01-12-2016, 10:01 PM   #89
Mrturner1
Put the new one in.
Cheap insurance.
Ok lol thanks for the reply
Old 01-12-2016, 10:03 PM   #90
Mrturner1
I really wanted to get the old cam out tonight because I'm dying to know what it is, but it's dark and about 35 degrees outside, and when I pulled on the cam it came out about an inch or two and then stopped, couldn't pull it any further
Old 01-12-2016, 10:17 PM   #91
trac209
Fuel pump rod is holding it perhaps? All the lifters out?
trac209 is offline   Reply With Quote
Old 01-12-2016, 10:23 PM   #92
Mrturner1
Haven't touched the fuel pump so that must be it. All the lifters are out. I'll be back at it tomarrow early, today was a lot of running around getting parts and tools. I'm really excited to see what the old cam was.
Old 01-12-2016, 11:01 PM   #93
toolboxchev
Put the new one in.
Cheap insurance.
X2 on that, a sloppy one can cost you some cam lobes, lifters, other valvetrain on the initial break in.
Its very important to get the break in done correctly!
toolboxchev is offline   Reply With Quote
Old 01-12-2016, 11:03 PM   #94
toolboxchev
Edelbrocks work! Plain and simple. and not technical at all!
Old 01-12-2016, 11:11 PM   #95
Money_pit
Money_pit's Avatar
Soo that's a pretty large cam unless I missed something. Probably need to be getting a stall for that thing. Gonna be a pretty rough idle. Might even be a good idea to drop the pan and put in a fel pro one piece. Did you get any confirmation about push rod length ?
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 01-12-2016, 11:59 PM   #96
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A short story... I had a 1967 C10 stepside shortbox back in the mid 1990's that was a snotty little beast. Had a rowdy 350 SBC in it. A buddy of mine acquired a 1960 C10 shortbed fleetside with a carbed TBI 305 V8. He bought it thinking it had a 350 in it. Come to find out after running the block numbers... the PO lied. So 350 shopping we went... found a worn out 350 at a junkyard and set to rebuild it. We took it apart and took the block, crank, and heads to the machine shop.
Machinist calls him couple days later to tell him it needs to be bored .030 over. I just happen to be there when he takes the call... with the machinist still on the phone, he asks me, "What's yer small block bored to?"
"Thirty over." I say.
He tells the guy, "Bore it forty over."
He always had to be "one up" on me...
You have to pull the fuel pump and remove the long pushrod that runs against an eccentric on the camshaft. The fuel pump arm is holding tension on the rod pinning the cam in it's place.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-13-2016, 12:54 AM   #97
GRX
GRX's Avatar
Been sitting back waiting for that one. Should be interesting.
Old 01-13-2016, 06:56 AM   #98
Mrturner1
Talking Re: Starting my engine build
It is going to need a bit of stall, I'm shooting for 2200-2500 at the most. Do you mean a one piece trans pan gasket? I picked up a deeper trans pan yesterday that holds a couple extra quarts of fluid, and I have a trans cooler as well. Definetly looking for the rough idle
Old 01-13-2016, 06:57 AM   #99
Mrturner1
Not sure what you mean by confirmation of rod length? I did get the valve springs Comp recommends for the heads though, they were almost a hundred freakin bucks just for springs
Old 01-13-2016, 07:00 AM   #100
Mrturner1
Pullin the fuel pump today, thanks for the tip guys. I looked at a couple other cams, the XE268, the XE274, and 270H Magnum, even a 292H which looks like loads of fun to me, but that was too big (next time though!) Looked at the Thumper Series but after a good bit of advice and some research I decided not to waste the money.
