#76 |
Re: Starting my engine build
40 over is always interesting. Often indicates the engine was rebuilt twice since 30 is the usual first step. Unless the cylinders were too worn for that the 1st time.
[edit] - looks like christmas all over again. Good to see the bottle of assembly lube along with the new cam. |
#77 |
I'm also swapping the Edelbrock 600 for a 650 AVS Edelbrock, but we'll see how it goes, might try a Holley 670
#78 |
I'm kinda wondering about the head gasket issue. It was said earlier that a 400 head gasket would be needed instead of replacement 350 SBC gaskets. Haven't bought them yet but I'll need to soon
#79 |
What's the specs on the cam?
#80 |
Only difference in the 400 gasket is the steam holes between the cylinders. If you are not running a 400 block, don't worry about it.
#81 |
New cam
#82 |
I can't get the center nut in the crank pulley loose....grrr busted knuckles
#83 | |
An impact is always handy there, but you should be able to get it with a breaker bar (or pipe on a sturdy socket driver) if you can keep the engine from turning instead. I've done that wedging a screwdriver in the flexplate holes, but I'm sure there's a better way someone will have to offer. You can also use a short piece of pipe or something and give it a whack. I forget the technical term, but even hitting it head on can sometimes "break" the thread lock. If you can get PB (liquid wrench) in there, the longer it can soak the better. Like overnight, or days.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#84 | |
#85 |
Got the timing cover off and found this, is this a double roller? Because if so I'll just return the one I bought today
#86 |
Turf that old double roller.
Put the new one in. Cheap insurance. |
#87 |
Can I ask how? I suggested a couple of things, curious as to which one worked so I know next time!
#88 |
#89 |
#90 |
I really wanted to get the old cam out tonight because I'm dying to know what it is, but it's dark and about 35 degrees outside, and when I pulled on the cam it came out about an inch or two and then stopped, couldn't pull it any further
#91 |
Fuel pump rod is holding it perhaps? All the lifters out?
#92 |
Haven't touched the fuel pump so that must be it. All the lifters are out. I'll be back at it tomarrow early, today was a lot of running around getting parts and tools. I'm really excited to see what the old cam was.
#93 |
![]() Join Date: Jul 2015
#94 |
#95 |
Soo that's a pretty large cam unless I missed something. Probably need to be getting a stall for that thing. Gonna be a pretty rough idle. Might even be a good idea to drop the pan and put in a fel pro one piece. Did you get any confirmation about push rod length ?
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. ![]() Last edited by Money_pit; 01-12-2016 at 11:22 PM. |
#96 | ||||
"I ain't nobody, dork."
Machinist calls him couple days later to tell him it needs to be bored .030 over. I just happen to be there when he takes the call... with the machinist still on the phone, he asks me, "What's yer small block bored to?" "Thirty over." I say. He tells the guy, "Bore it forty over." He always had to be "one up" on me... ![]() Quote:
Gary
#97 |
#98 | |
![]() Quote:
#99 |
#100 |
Pullin the fuel pump today, thanks for the tip guys. I looked at a couple other cams, the XE268, the XE274, and 270H Magnum, even a 292H which looks like loads of fun to me, but that was too big (next time though!) Looked at the Thumper Series but after a good bit of advice and some research I decided not to waste the money.
