Brake pressure question
I just replaced 2 wheel cylinders & brakes all around on a 63 non power brakes. We bled all 4 cylinders it builds pressure on ea one, but when I go to step on the brake it slowly go's down once then it builds pressure again. if I let it sit it does the same go's down then builds pressure. any ideas?
Re: Brake pressure question
Do ya know the master cyl. is good for sure?
Hollister, CA.
![]() Join Date: Sep 2006
Sounds like the master is bad.
Did you replace the master as well ? If so, did you bench it first ? Traces of a leak down firewall ?
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
When you say "it goes down" do you mean it goes close to the floor and you can pump it a few times and the pedal comes up ? or that with pressure on the pedal it slowly goes down to the floor?
How about adjusting the brake shoes back out till they just start to touch? then back a turn maybe
YEP sounds like brake adj is needed and possibly still some air in the system
60-66 Nut
I agree that it sounds like a bad master. It could have an internal leak. My DD '68 had a similar issue. I replaced all the shoes and one leaky wheel cylinder, hoping that might be it but I still ended up replacing the master. Now I have good brakes.....well as good as manual drum/drum brakes can be.
I'll start with the adjustment & hope that does the trick, If not proceed with the master.
Thanks guys |
All it needed was a brake adjustment, Thanks guys
