Old 01-21-2016, 06:28 PM   #1
7tee
7tee's Avatar
Need some help about which engine perches...
I'm helping a friend with an engine swap from 250 6 cylinder to a 6.0 L with an LT1 6 speed. The question is which engine perches and or motor mounts will work for this set up? Thanks for your help...ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 01-22-2016, 07:13 AM   #2
7tee
7tee's Avatar
Re: Need some help about which engine perches...
ttt
2010 Acura RL...
Old 01-22-2016, 07:54 AM   #3
7tee
7tee's Avatar
Is this what you use for the 6.0L swap or just regular v-8 perches or towers?
2010 Acura RL...
Old 01-22-2016, 08:25 AM   #4
gottattooz
gottattooz's Avatar
I used the factory engine mount brackets at the frame and ls motor mount adapter brackets at the engine. If you search "ls swap brackets" on eBay, then input the vehicle you're working on, it'll narrow down your search.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 01-22-2016, 09:28 AM   #5
7tee
7tee's Avatar
-Josh
So are you saying you used the 6 cylinder position and perches with the LS swap brackets? Do you mind sharing which bracket supplier and stock #? Thanks for your response...ed...
2010 Acura RL...
Old 01-22-2016, 09:42 AM   #6
68Stepbed
68Stepbed's Avatar
I used the POL tubular mounts in the 6-cylinder location. Here's my reasoning. 1. I wanted the engine as far back as I could get it for better weight distribution. 2. The tubular mounts are stronger(less flex) and provide better clearance for exhaust manifolds, headers, etc.
However, you can use the stock 6 cylinder mounts and just use adapter plates. The stock manifolds will most likely interfere, though.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-22-2016, 09:56 AM   #7
7tee
7tee's Avatar
This is why I'm getting my friend to join the forum, the knowledge here is unlimited...
Perfect, just what I needed, pics and the reason why. BTW you have a beautiful set up. Thanks 68stepbed, you the man...ed...
2010 Acura RL...
Old 01-22-2016, 10:13 AM   #8
68Stepbed
68Stepbed's Avatar
Always glad to help!
Matt
Old 01-22-2016, 12:37 PM   #9
michael bustamante
michael bustamante's Avatar
on your set up, (nice) did you use the dirty dingo slider mounts along with those perches? I want my ls to slide all the way back as well.
1967custom
michael bustamante is offline   Reply With Quote
Old 01-22-2016, 03:48 PM   #10
68Stepbed
68Stepbed's Avatar
No, I used TransDapt plates. I'll never use them again. Some of the holes were slightly off, and I had to drill them out bigger to get the bolts to line up. I also bought a kit that had motor mounts with it. I had to replace them last year with Energy Suspension mounts because the metal was fatiguing due to being poorly and cheaply made. I'll use Dirty Dingo mounts if/when I do another LS swap.
Matt
Old 01-22-2016, 10:04 PM   #11
Pro Performance
Pro Performance's Avatar
The Dirty Dingo mounts work great, and slide for some adjustability. All high grade steel and Grade 8 or higher hardware. No mods needed on the stock engine perches.
http://www.azproperformance.com/Dirty-Dingo-67-72-C10/
Pro Performance is offline   Reply With Quote
