Old 08-29-2010, 11:43 AM   #1
PRattenbury
Torque value-Pitman Arm Nut??
As the title says, I am looking for the correct torque value to apply to the nut that holds the pitman arm to the steering box shaft. 1980 C10 SWB pickup, power steering. Thanks!
PRattenbury is offline   Reply With Quote
Old 08-30-2010, 02:11 AM   #2
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Re: Torque value-Pitman Arm Nut??
My 74 service manual says pitman arm to pitman arm shaft nut 180 lbs ft power steering, 140 lbs ft manual. Pitman to relay rod 60 lbs ft. I would think 1980 with be the same values.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-30-2010, 01:18 PM   #3
PRattenbury
Thanks! Now I gotta find a torque wrench that goes higher than my 150 ft/lb wrench does...
Old 08-30-2010, 02:29 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My torque wrench only went to 140 or 150. I pulled until it clicked, then pulled for one more grunt for good measure.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-30-2010, 05:36 PM   #5
PRattenbury
I just ran mine up to 150. That's pretty tight.
Old 01-27-2016, 07:58 PM   #6
mattcrp1
mattcrp1's Avatar
thanks
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 01-27-2016, 08:13 PM   #7
mattcrp1
mattcrp1's Avatar
Quick note, I hit with my 1/2 impact and then checked it with a 3ft torque wrench. It took some more turning with the wrench to hit the 180ftlb mark.
IG mattcrp1
