Old 01-23-2016, 04:01 PM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: CB Radio question
Some of the unit when I got,The CB guts are in the second box.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-29-2016, 01:42 PM   #27
chiro22
chiro22's Avatar
Any opinions on which of these simple models would be the best option?
found this handled one that converts:
Amazon.com: Midland 75-822 40 Channel CB-Way... Amazon.com: Midland 75-822 40 Channel CB-Way...
or this mountable one:
Amazon.com: Uniden 40-Channel CB Radio... Amazon.com: Uniden 40-Channel CB Radio...
Also both of these look like they could plug into the cigarette lighter and work. The mountable one needs a converter to do that. Does that mean I would just plug it into the lighter, connect to the antenna and be ready to go>?
Thank you,
Doc
1973 Cheyenne
"I get up in the morning looking for an adventure."
chiro22 is offline   Reply With Quote
Old 01-29-2016, 02:13 PM   #28
Liberty
Liberty's Avatar
I wouldn't power it through the cig lighter if you don't have to.
Just wire it up to the fuse panel, crimp some of those cheapo speaker connectors to the wiring of the CB.
Liberty is offline   Reply With Quote
Old 01-29-2016, 06:55 PM   #29
chiro22
chiro22's Avatar
Sounds good. I'll look into doing that. I'm sure there some online tutorials.
Thank you,
Doc
1973 Cheyenne
Old 02-05-2016, 01:22 PM   #30
chiro22
chiro22's Avatar
Anyone have a strong opinion on antennas? I was looking at the 4-5' fiberglass Fire Stick and a stake hole mount, or a wilson/cobra magnetic mount and finally a 102" whip with ball joint and tie down. I've heard the 102 can have high swr while driving because it bends.
This is a weekend warrior, hunting truck, so I was considering the magnet so I can pull it off when I'm not using it.
Thoughts?
Thank you,
Doc
1973 Cheyenne
Old 02-05-2016, 01:26 PM   #31
chiro22
chiro22's Avatar
Also where do people run the coax, window seals, drain plugs, drill new holes?
Thank you,
Doc
1973 Cheyenne
Old 02-08-2016, 09:32 PM   #32
chiro22
chiro22's Avatar
^^^bump
Thank you,
Doc
1973 Cheyenne
Old 02-08-2016, 10:35 PM   #33
Eraser475
Eraser475's Avatar
Here's my setup. 1976 Midland 23 Channel. 2 3' Firestik FS-4 Tunable tip antennas. Mounted to the front of my toolbox. 18' Coax run between the bed and cab, along the frame rail, and around the front of the cab through the firewall. The extra is coiled in a figure 8 under the dash since I've heard you can get interference if it's just a single coil. I honestly haven't had a chance to test the range on it yet since I don't drive it on the salty Minnesota roads. I would have 4' antennas if I had the clearance for them in my garage. If I were you, I'd go with a single 4-5' Firestik antenna and tune it correctly
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 02-10-2016, 06:04 PM   #34
chiro22
chiro22's Avatar
Great looking set up and GREAT shifter head!! haha
Thank you,
Doc
1973 Cheyenne
Old 02-11-2016, 02:48 AM   #35
chiro22
chiro22's Avatar
Does anyone know of a shop in the Bay Area that has and can install cb/antennas?
Thank you,
Doc
1973 Cheyenne
Old 02-16-2016, 05:17 PM   #36
jjmorrse
They are not at all difficult to install and set swr, if a person is deliberate about it. If nobody suggests a place in your area, a lot of times interstate truck stop staff will know who might be good locally.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 02-17-2016, 01:05 AM   #37
chiro22
chiro22's Avatar
Thanks!
Thank you,
Doc
1973 Cheyenne
Old 02-19-2016, 10:18 AM   #38
Prerunner1982
Prerunner1982's Avatar
Thoughts?
A 102" whip (with a spring) is the best antenna option you can run. Downside is that it's long, but it works well. The shorter the antenna the more of a compromise. You could also run the 102" whip on the stake hole mount if you want, unless you just like the ball mount whip look. If you are just wanting it to talk to your hunting buddies that are in same general area you could get by with a shorter antenna.
Instead of coiling the coax you can also shorten the coax and use just what you need. No reason to have to find a place to stash all the extra especially if it is only mounted to your toolbox.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
