Old 02-10-2016, 06:39 PM   #1
im4darush
Removing 72 E-Brake handle...
Is there a trick to this? Or is this a cut off operation?
im4darush is offline   Reply With Quote
Old 02-10-2016, 07:13 PM   #2
cypressbog
Go Pack Go!
Re: Removing 72 E-Brake handle...
There's 2 nuts on firewall (engine side) and 1 nut under dash. I think you need to remove a number of dash bolts in order to be able to flex the dash enough to get the assembly out because it still has the studs.
cypressbog is offline   Reply With Quote
Old 02-10-2016, 11:01 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Don't need to remove bolts it should be able to shift sideways enough to remove it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-11-2016, 11:28 AM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: Removing 72 E-Brake handle...
I had a devil of a time taking mine out, I took out the three bolts on the drivers side of the dash and that gave me ample room to flex it out.
Going back in was almost as difficult.
Ben
snipescastle2 is offline   Reply With Quote
Old 02-11-2016, 11:32 AM   #5
Bigdav160
Bigdav160's Avatar
The handle is barb fit on the rod. Mine broke trying to remove it. Bought a replacement.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-11-2016, 11:37 AM   #6
snipescastle2
I believe he was referring to removal of the pedal assembly, and I'm pretty sure the black plastic "T-handle"(that says brake release) is threaded.
Ben
Old 02-11-2016, 12:00 PM   #7
im4darush
I should have been more clear....was really asking about the black release handle, not the pedal assembly.
Old 02-11-2016, 12:02 PM   #8
70STOVEBOLT
Just unscrew it, the release rod is threaded.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-11-2016, 12:20 PM   #9
im4darush
Thanks. Im guessing the PO must have glued it on as it was maybe lose? Thing will not budge. I will consult with mr. dremel.
Old 02-11-2016, 01:16 PM   #10
70STOVEBOLT
He should be able to take care of it.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
