Old 02-10-2016, 08:53 PM   #1
knhracing524
Tilt front end
Curious if anyone has any ideas or pics of hinges for a tilt front end. Using all steel and core support. Thanks. This is my first post.
knhracing524 is offline   Reply With Quote
Old 02-10-2016, 09:51 PM   #2
franken
Re: Tilt front end
Is this a race application, or?
Fibreglass?
Details?
franken is online now   Reply With Quote
Old 02-10-2016, 10:26 PM   #3
knhracing524
Fibreglass?
Details?
Street application. Using all factory steel. Want to use factory core support to tilt. Have seen it done. Need ideas for hinges.
Old 02-10-2016, 11:17 PM   #4
Oldblue68chevy
Re: Tilt front end
I havent done a tilt front end personally but a friend of mine built a 55 chevy gasser. He used some linear bearngs to allow the front end to slide forward befor it tilts. This allows the bottoms of the fenders to clear the doors. I would also think you might need some sort of assist cylinder to help lift and slow the lowering. Not sure how it would balance out being all steel might make it a bit heavy. I do think it would be pretty cool on a truck and give you pretty good acess to work on the motor.
Oldblue68chevy is offline   Reply With Quote
Old 02-11-2016, 02:34 PM   #5
New_70'C10
New_70'C10's Avatar
Re: Tilt front end
Not that this helps but I did see a diagram of this exact setup on here a couple of days ago. I did a quick Google search and saw some pretty good ideas there.
1970 SWB CST; 307ci, 200-4R, (Slow Motion)
New_70'C10 is offline   Reply With Quote
Old 02-11-2016, 03:09 PM   #6
ptc
ptc's Avatar
Re: Tilt front end
The best ideas I have seen for street applications use the linear bearings like has been said. Find them at McMaster Carr and all your hardware for it should be available there. LEave the raiator support and everything where its at, build a new cross support out of 1" box tube that supports the whole front. For the rear use 3/4" solid round stock as Pins that drive into holes you align with the body at the lower doors. There you can put pins or latches etc to lock it shut.
Linear bearings using a shaft to move it forward will mount to the frame rail. the front end of the shaft will connect to your lower bumper cross rail with a rod end.
This guy made a video of it (its a gasser but same idea as a truck front end):
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-11-2016, 07:47 PM   #7
john
member #16
john's Avatar
Re: Tilt front end
crazy longhorn has a steel tilt front end on his longhorn. There is a pic in this thread.
http://67-72chevytrucks.com/vboard/s...ad.php?t=34761
john is offline   Reply With Quote
Old 02-11-2016, 09:01 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Tilt front end
Welcome! Board member Frenchblue72 converted to a tilt hood back in 2009. There's a few pics here http://67-72chevytrucks.com/vboard/s...=267665&page=5 -- not sure how much info is in the thread or if there are any more pics.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
