Chance
![]() Join Date: Sep 2001
1972 big block alternator brackets install
Does anyone have a picture of the 1972 big block alternator brackets installed? Specifically the rear support rod. Where does it bolt to on the engine? How is it attached? Thanks in advance.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
Re: 1972 big block alternator brackets install
Is it different than 1970? I can get pics of that, but don't know if it's the same (PM me if it is and I forget!)
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Chance
As far as I know the 1972 big block alternator brackets are a one year only style.
Member #1049
Correct, it is a 72 only bracket setup,
You should be able to make out the rear rod attachment in this pictures |
Chance
It looks like it attaches to a bolt which secures the header. I have stick manifolds on mine. I wonder if it attaches the same way.
A couple pics of mine. It is a 71 but have a lot of parts from 72.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
Chance
Looks like it goes behind the exhaust manifold. Am I seeing that correct?
#8 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Ipads are good for blowing up pics.
It actually goes to a bolt above the exhaust bolt, sorry for the bad pic.
Chance
Looks great. I'll see if my heads have that bolt hole. Thanks!
Scrapper 1
you know you can use the 327 water out let on your intake manifold Last place i want a sending unit wire is next to them Hot exhaust manifolds.The new M&H harness sits right on top of the intake manifold next to the valve cover and it looks cleaner look
