Old 02-19-2016, 06:25 PM   #1
Backpayne
Parking brake using Lokar cables
My '64 only has the parking brake handle (under dash) with the cable that goes through floorboard, nothing else. Would I be able to buy this: Amazon.com: Lokar EC-80FU Universal Emergency... Amazon.com: Lokar EC-80FU Universal Emergency... and connect all together for a functioning ebrake? I thought about piecing together a '67 style ebrake, but the Lokar set looks easier and cleaner.
Thoughts?
Thanks!
Backpayne is offline   Reply With Quote
Old 02-19-2016, 07:05 PM   #2
Re: Parking brake using Lokar cables
I am not positive about the Lokar, but you are going to need the cable braces if you plan to do the 66 & newer e brake cables. For the 65 there is a cross member you need for the cables. I don't have access to my photos where I am at now, but hopefully some one else can chime in/show you what you need besides the cables.
Old 02-19-2016, 07:19 PM   #3
Backpayne
The braces are another reason why I am looking at the Lokar set. It looks like going aftermarket may be the only viable option.
Old 02-19-2016, 07:43 PM   #4
mehoff400
would any of this work for ya?
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=87
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 02-20-2016, 10:00 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Start here:
http://67-72chevytrucks.com/vboard/s...50&postcount=8
Then use your Lokar set up like this:
http://67-72chevytrucks.com/vboard/s...46&postcount=4
To the rear trailing arms:
http://67-72chevytrucks.com/vboard/s...2&postcount=17
Old 02-20-2016, 11:27 AM   #6
Backpayne
I think I have it all figured with the last two posts! Now to spend some money.
