Old 02-20-2016, 07:00 PM   #1
russellrox
custom engine bay wiring ideas for LS swap
I have smoothed out most of my firewall, got rid of the heater box and all holes other than the necessary ones. I am putting a 5.3L in it and am wondering where have you guys ran the harness so it's very clean and not visible. I am going to be putting the fuse panel and ecm under the dash in behind the glove box. Anything helps so keep it going. I was going to do a bulkhead connector for the engine and body harness so it's sealed and easy to access.
russellrox is offline   Reply With Quote
Old 02-20-2016, 08:12 PM   #2
PGSigns
PGSigns's Avatar
Re: custom engine bay wiring ideas for LS swap
Check out the LS swap section for ideas and also may be a better place to ask this question.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-20-2016, 10:59 PM   #3
Clyde65
Clyde65's Avatar
Some aftermarket harnesses run under the intake....
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
