Old 02-18-2016, 01:50 PM   #501
Mrturner1
Re: Starting my engine build
Originally Posted by davepl View Post
One thing I like to do is to make sure I finish a sub-project such that the vehicle runs and drives. So if I was going to do some engine work and then some suspension work, I'd want to get it on the road and sorted out and debugged on the engine work before I started the suspension work.
Normally, since none of us are perfect and few of us are professionals, you build up a set of "bugs" that need to be fixed, but if you don't stop along the way to fix those, they just accumulate so that when you want to go out and test your new brakes you find out it stalls instead of driving. Too hard to fix multiple things at once, so get it back up and running right in between projects.
Hope that makes sense.
Yep I'm mowin what your growin I'd like to get the truck all the way into the garage and up pretty high on jack stands while doing the suspension too. No point in breaking my back and trying to squeeze under this thing. Pulling it in will be much easier with a running truck. I'll have to resist the urge to romp on it I guess until the whole truck is ready lol
Mrturner1 is offline   Reply With Quote
Old 02-18-2016, 01:52 PM   #502
Mrturner1
Originally Posted by toolboxchev View Post
My suggestion would be to clean everything and just get your engine done first. Why? MONEY!
It starts getting expensive fast also. Look at some of the rigs on here, I read one about a driver that slowly turned into a drag racer over the course of 20-30 years.
You can always do more work to your project, fun ride. It can break the bank if your not careful.
Me I am going out to fix a heater wire.
I was actually trying to remind myself of that a few times when the short block was bare. I wanted to go 383 so bad lol this is a good point though, nothing says I can't tear it back down in a few years
Old 02-18-2016, 02:22 PM   #503
Mrturner1
Just curious, did the blower motor stop working because mine doesn't blow and I have zero experience with heaters
Old 02-19-2016, 12:17 AM   #504
Average Joe
Average Joe's Avatar
Originally Posted by Grumpy old man View Post
Find a stock heavy front sway bar from a c-20 in the parts section and then buy a rear bar from one of the vendors and matching spring shock kits .
Great advice! I bet you could find one in a wrecking yard for under 30 bux. Easy swap and by far the best bang for the buck. Any bar off a 2wd from a 73-87 will work as well.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-19-2016, 04:15 AM   #505
toolboxchev
Everything has been replaced on the system except 2 things, the wiring and the silly voltage regulator for the heater system.
I ran a wire from the fuse panel heater location to a switch on the aftermarket tach mount direct to a new blower motor.
They are fairly simple systems, everything is covered in electrical. What is not there you can figure out by the wiring diagram and some basic electrical google search.
Again the nice thing about these rigs, simplicity.
toolboxchev is offline   Reply With Quote
Old 02-19-2016, 07:39 AM   #506
Grumpy old man
Grumpy old man's Avatar
Are the C20 front bars better than aftermarket? Just curious because that sounds like one of those bits you've learned after doing a few truck builds
Also, I can't see what clamp you mean on the helper springs, but I'm wondering why it has helped springs anyway. Still can't find the SPID or I'd know alot more about this truck
AND...is there a benefit to switching to 5 lug when doing brake kits? Been looking around at lots of front disk brake kits and seems like a lot of guys go to 5 lug
(They are bigger and mount different than after market)
(I saw a picture of your rear axle and it shows 2 springs mounted to the rear axle with u bolt clamps ? Take a few pictures of your rear suspension so we can see whats going on ?)
( there are more wheel/axle choices for 5 lug )
Old 02-22-2016, 05:09 PM   #507
Mrturner1
Back to work finally! I went with the Performer RPM, no air gap this time. Saw a lot of dyno sheets showing about 6-7 hp increase with the air gap, but I want to keep the drivability
Old 02-22-2016, 05:45 PM   #508
Mrturner1
What's the best way to make sure the timing is set right and to drop the distributor in? I read to rotate the engine to 5 degrees BTDC, then put distributor in with number one wire lined up with the pointer
Old 02-22-2016, 06:54 PM   #509
Mrturner1
I went with the satin finish and I think that was a good call by somebody earlier in the thread. The combination or satin and bits of chrome here and there will look great
Old 02-22-2016, 06:57 PM   #510
Mrturner1
Front
Old 02-22-2016, 07:00 PM   #511
Davidf
If you lined up the dots on the cam and crank gear, don't forget to rotate crank 360 degrees before installing distributor pointing to plug wire #1. If you don't, you distributor timing will be 180 degrees out.
Davidf is offline   Reply With Quote
Old 02-22-2016, 07:24 PM   #512
Mrturner1
Thanks for the quick response!
Ok so it was at #1 TDC and I adjusted half the valves, then I turned it one full rotation so the #6 was at TDC, then adjusted the remaining valves. I haven't rotated it since, so just to clarify, I need to rotate one more full turn to be back at #1 TDC and THEN drop the distributor, correct?
Old 02-22-2016, 09:10 PM   #513
Mrturner1
One other thing, can I make the #1 cylinder any spot I want on the distributor? And then go with firing order clockwise from there?
Old 02-22-2016, 10:06 PM   #514
geezer#99
geezer#99's Avatar
Sure you can.
If you where on 6 oclock on the cam gear and 12 oclock on the crank gear when you started out, then at that time you where on #6tdc.
To be safe on whether you're on #1 or #6 tdc, it's easier to pull #1 plug, feel for compression, line up your timing tab at zero, then install your distributor with rotor pointing at #1.
geezer#99 is online now   Reply With Quote
Old 02-22-2016, 10:18 PM   #515
Mrturner1
Originally Posted by geezer#99 View Post
Sure you can.
Thanks! I'll check it to be on the safe side
Old 02-22-2016, 10:20 PM   #516
Mrturner1
I pulled a rookie move and a few weeks ago I bought a water pump and painted it before I compared it to the old one. Parts guy said it was for a 70' but it's a short pump when my old one is a long pump. Can't return it cuz it's painted, so how much changes from long to short? Pulleys? Other stuff? I'm switching to electric fans so no need for the clutch fan if that matters
Old 02-22-2016, 11:39 PM   #517
Mrturner1
Probably a silly question but is it okay that there's paint on the surface where the water pump gasket sits?
Old 02-22-2016, 11:51 PM   #518
Mrturner1
What can I use safely to clean up this starter? May just get a new one if I can't clean this one up
Old 02-23-2016, 12:29 AM   #519
Captainfab
60-66 Nut
All trucks '72 and earlier came from the factory with short water pumps. The pulleys and accessory mounting brackets are different between a short and long water pump. If your engine previously had a long water pump and all the pulleys l;ined up, then you will need another long water pump. Be aware that there are 2 variations in the V-belt type long water pumps for the small block. The difference is in the boss for the alternator top bracket and the hole for the power steering pump bracket. It will be either a smooth bore or threaded.
Old 02-23-2016, 03:14 AM   #520
Mrturner1
It's almost midnight I'm throwing in the towel
Old 02-23-2016, 03:17 AM   #521
Mrturner1
Pic
Old 02-23-2016, 03:21 AM   #522
Mrturner1
Looking like an engine again finally. I got new MSD plug wires but I wanted to see how it looked with the old ones. The old ones aren't long enough for the wire looms so I'm gonna ditch them and use the new red MSD ones
Old 02-23-2016, 04:59 AM   #523
swamp rat
swamp rat's Avatar
Did you put RTV (coolant resistant) on the water pump gaskets? Or did they have the sealant on them? Did you put thread sealant on the bolts that go into the water jacket?
Per the paint on the water pump gasket area, i always scrape it off with my gasket scraper off so i cant tell you if it matters.
Per the starter i would probably use what ever i could find available, carb or brake cleaner, or the stuff you cleaned the block with.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-23-2016, 12:27 PM   #524
Mrturner1
Yep put a small film around the water pump gasket and sealant on all 4 bolts. Today I'm going to try and get the plug wires made and start on the motor well. I thought the plug wires came already the right length and built but apparently not. I don't have a vice so I need to figure out how to go about crimping the ends
Old 02-23-2016, 01:38 PM   #525
swamp rat
swamp rat's Avatar
spark plug wire crimping tool
Google this.... click images
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
