Old 02-06-2016, 02:05 AM   #1
Russ.W.
Russ.W.'s Avatar
Exclamation Found: 12 Bolt rearend (for leaf spring truck)
Edit: Found one! Thanks folks.
Old 02-06-2016, 09:28 AM   #2
1rippen6
Re: Wanted: 12 Bolt rearend (for leaf spring truck)
I have several 12 bolts out of blazers may have to move the spring pad width. I would ship through fastenal so someone would need to pick it up at the other end is that doable? If that is possible I can get you some pictures.
1rippen6 is offline   Reply With Quote
Old 02-06-2016, 12:35 PM   #3
gpgofast
Originally Posted by Russ.W. View Post
G'day folks.
Looking for a 12 Bolt rearend for a '67 C10.
Housing must have leaf spring mounts/brackets
Axles/lugs/ratio etc not important. They will be replaced unless it's a perfect combo in great condition.
A bare housing would be ideal.
Seller needs to be willing to have it shipped to my shipping agents in Kelso, Washington. 98626.
I live in Australia so I can't pick it up
I can only pay via PayPal, and I will absolutely need pics.
Thanks for your time.
Cheers,
Russ
I will have one out of my 1971 1/2 ton K10 4X4. In relatively good shape. Please PM me for details. PS. I live in Washington state, so I may be able to deliver for a fee.
gpgofast is offline   Reply With Quote
Old 02-06-2016, 09:56 PM   #4
Russ.W.
Russ.W.'s Avatar
Unfortunately, I believe 71's are a different width. I'm not interested in modifying housings (with the exception of relocating leaf mounts). Sorry.
Old 02-06-2016, 09:58 PM   #5
Russ.W.
Russ.W.'s Avatar
I'm not sure that's possible but I will send them an email and check.
Old 02-06-2016, 10:02 PM   #6
1rippen6
The ones I have are out of 72 blazers if that will work.
Old 02-06-2016, 10:27 PM   #7
Russ.W.
Russ.W.'s Avatar
I'm under the impression 72's are a different width. Sorry. I can't use them.
Old 02-06-2016, 10:28 PM   #8
1rippen6
No problem I can get a measurement if you know what you need
Old 02-21-2016, 03:52 AM   #9
Russ.W.
Russ.W.'s Avatar
Bump.
Still in desperate need of one.
Old 02-21-2016, 07:40 PM   #10
HONDAWASAKI
I have a leaf spring rear end already pulled, but I am not sure if it is a '69, or '70 it measures 58 1/4 flange to flange. Do you have measurements? I also have a '67 coil spring rear end next to it for reference, were they the same width? The coil spring housing measures 56 3/4 flange to flange. So its probably from an '70.
'67 C10 shortie.
HONDAWASAKI is offline   Reply With Quote
Old 02-21-2016, 08:35 PM   #11
un4gvn!
un4gvn!'s Avatar
I have one with a flip kit if you are lowering it. 100 for just the bare housing. I also have the rest of this rear-end like the series 4 carrier with 4:10 gears, Kal-tech traction, and new shocks. I wouldn't know where to begin on shipping it.
un4gvn! is offline   Reply With Quote
Old 02-22-2016, 09:01 PM   #12
Russ.W.
Russ.W.'s Avatar
Thanks for the response guys. My diff measures exactly 57" from outside of flange, to outside of flange, or 56.5" from inside of flange to inside of flange.
When measuring from outside of flange: 57" (57inch / 4ft 9inch / 1448mm)
When measuring from inside of flange: 56 1/2" (56.5inch / 4ft 8.5inch / 1433mm)
Old 02-23-2016, 12:00 AM   #13
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I think I have one from my 69 GMC I will measure in the morning. Even if correct , not sure how to go about the shipping but can check on that as well
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 02-23-2016, 02:49 AM   #14
Russ.W.
Russ.W.'s Avatar
I appreciate that. Thanks.
Old 02-26-2016, 09:59 AM   #15
richard2717
Russ
The rear end I have is correct but it has some heavy gouges and pitting in the axle tubes on both sides. I tried several times to get some decent pictures but they are not showing up well in the pics. I did attach the best one
Members I have met.
Old 02-27-2016, 02:59 AM   #16
Russ.W.
Russ.W.'s Avatar
Russ
The rear end I have is correct but it has some heavy gouges and pitting in the axle tubes on both sides. I tried several times to get some decent pictures but they are not showing up well in the pics. I did attach the best one.
Thanks Richard. Unfortunately I will have to pass. That doesn't look a whole lot better than the one I already have. Surface rust is fine, but pitting I need to keep away from.
I appreciate the effort though. Thank you.
Old 02-27-2016, 04:04 AM   #17
Sklptrljay
Sklptrljay's Avatar
Size:  106.9 KBGive this guy a call.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
12 bolt, diff, leaf, rearend
