Old 03-02-2016, 06:39 PM   #1
Chevy3+3
Re: 454 smog pump delete
Originally Posted by Nodnarb76 View Post
When I removed mine I just left it unplugged, had no problems.
Sweet! DO you know what that thing is that the wire was connected to? Only reason I ask is because if it doesn't change anything when its unplugged then it probably didn't do anything to start with. just seems wierd
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 03-02-2016, 06:56 PM   #2
Nodnarb76
Nodnarb76's Avatar
Looks like it got a signal from the PCM to open/close. I recently removed the whole TBI harness and traced the plug back to the PCM. I had no check engine lights when I left it unplugged. Looks like it
just tells it to open or close, and does not get any info back to the pcm.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
