#26 |
Re: charging system
If your truck runs on after connecting the #1 to the ignition you may need to also add a diode. I had that problem years ago using one of those alternators on a Case tractor. IIRC I used a switch to excite it and then turned it off. I didn't know much about them at that time.
Just so no one wants to poke me in the eye with a sharp stick I leave my original wiring intact and just add to it. But even with a truck messed up and with an original wiring diagram in hand, it is usually not too hard to figure them out. Some jurisdictions get quite picky when it comes to issuing antique or collector plates and if I move to the next province over I can anticipate having to put it back to original. |
#27 | |
Re: charging system
hey PGSigns do you have any pics of how you ran your ground straps ? so i can see just where to run mine at ? it would be most helpful this way i could replicate yours ... i bought some grounding straps from ebay they are on the way and also some 8 AWG wire for the alt i also bought some heat shrink and some non covered connectors that i will use to crimp the wires together and solider together and then cover with the heat shrink . i also bought a junction post to ... so let me know if im on the right track ... and hopefully you have some pics of how and where to put my ground straps at thanks again for all your help and understanding .... Happy Truckin ![]() |
#28 | |
Re: charging system
#29 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: charging system
That aint right:
#30 |
Re: charging system
#31 |
Moderator
Re: charging system
Depending upon if you have a normal horn relay or not there are numerous pictures of how to wire a 12SI alternator:
https://www.bing.com/images/search?q...ng&FORM=HDRSC2 Years ago I purchased a booklet on how to wire an automobile, I used to think it was FM.
#32 |
![]() Join Date: Jan 2011
Re: charging system
I'll look to see what I have for pictures.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#33 |
Re: charging system
#34 |
Re: charging system
PGSigns were you able to find me some pics on where to put my grounds? & Also this is what I bought. Is this what you had in mind for me to use ? All stuff made in the USA
