Old 03-14-2016, 05:44 PM   #1
Figuarus
Figuarus's Avatar
Updating control arm shafts.
So, question, because i'm not too clear on what I need to do, or if this is possible.
When did they upper control arm shafts on the 1/2 tons go to a bushing, instead of the metal nut on my 64?
AND,
Can I retrofit a rubber bushing shaft kit using my 64 control arms?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 03-14-2016, 06:51 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Updating control arm shafts.
Changed in '73 because the rubber bushing are quieter and make for a more "plush" ride.
No you cannot retrofit rubber bushing into the original arms. You would have to replace the arms with '73 and later.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-15-2016, 10:16 AM   #3
Figuarus
Figuarus's Avatar
Gotcha. Ok. sounds good. thanks!
2013 Malibu LTZ
