03-17-2016, 05:08 AM | #51 |
Re: Stock Manifold Options for LS Swaps
my stock manifolds have 3 studs came off a 04 1500 2wd truck. the part numbers I see being thrown around show the same damn thing I have. you have the set up I need. Part number make model of vehicle used for originally?????Pretty please?
1960 SWB “Pops” If you won't support our troops then stand in front of them! |
03-17-2016, 05:12 AM | #52 | |
Collector of Projects
The manifold pictured with the ruler is a 2010+ Camaro manifold. |
03-17-2016, 05:19 AM | #53 |
thanks
01-20-2021, 01:26 PM | #54 |
Raising the dead here... any chance the collector flanges and down pipes from a 5.3 Silverado would fit the TBSS manifolds? I see they both use a 3 bolt flange.
01-21-2021, 04:55 PM | #55 | |
Personally, I was not a fan of the TBSS manifolds. I mocked up a set, but really didn't like the way the driver's side kicked out into the frame(truck in signature). I bought a used set of 2010-15 Camaro manifolds, and love the fitment of those.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
01-22-2021, 08:47 AM | #56 |
$100 take-offs......2010 Camaro
removed heat shields and smoothed........fit like a glove 67 c10 LS1
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-31-2021, 10:44 PM | #57 |
A1971Blazer- that's a clean setup you have there. I wound up ordering the TBSS manifolds but I like the looks for yours better.
02-23-2021, 04:05 PM | #58 |
Going to bring this up again...
Anyone know if the 2017 Camaro manifolds will work on a '03 5.3? Putting a 2003 Tahoe engine into my '71 C10 and found a nice pair of 2017 Camaro manifolds for cheap.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
02-23-2021, 04:10 PM | #59 |
Has anyone used the Hedman cast manifolds?
02-23-2021, 04:30 PM | #60 |
Those manifolds will not work. The 2017 Camaro had the gen-5 "LT" engine, and was either the LT1 or the LT4. These had five bolts to hold the exhaust in place, instead of the six bolts that the LS engine used. The exhaust manifold is set up different too, because the ports are in a different position compared to the LS engines.
02-23-2021, 04:34 PM | #61 | |
02-24-2021, 11:10 AM | #62 |
We installed the Summit Racing brand cast manifolds on my brother’s ‘66 back
in September. Not the Hedman’s but damn near. They fit great and seem to be very good quality also. I can get a pic of them installed later. It’s currently his daily driver, zero issues.. |
Tags |
fuvk off |
