Old 03-17-2016, 05:08 AM   #51
badherb
badherb's Avatar
Re: Stock Manifold Options for LS Swaps
Originally Posted by mcmlxix View Post
Its 7" from the last manifold bolt on the head straight down to the flat gasket surface of the flange.
It sticks out 5.25" from the side of the block at its widest point. (Opposte of where the starter would attach.)
my stock manifolds have 3 studs came off a 04 1500 2wd truck. the part numbers I see being thrown around show the same damn thing I have. you have the set up I need. Part number make model of vehicle used for originally?????Pretty please?
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 03-17-2016, 05:12 AM   #52
mcmlxix
Collector of Projects
mcmlxix's Avatar
The right side was the stock 3 stud Sierra|Silverado manifold.
The manifold pictured with the ruler is a 2010+ Camaro manifold.
Also test fit the 2010 Camaro manifold... Camaro on the left, Sierra on the right...
Rich
1972 K5 Blazer CST Click HERE
Old 03-17-2016, 05:19 AM   #53
badherb
badherb's Avatar
thanks
1960 SWB “Pops”
Old 01-20-2021, 01:26 PM   #54
1972CST
1972CST's Avatar
Raising the dead here... any chance the collector flanges and down pipes from a 5.3 Silverado would fit the TBSS manifolds? I see they both use a 3 bolt flange.
1972CST is offline   Reply With Quote
Old 01-21-2021, 04:55 PM   #55
kipps
They're at least clocked very differently. I recall trying them, but I'm a little fuzzy on the results. I think though, that they do physically slide into place.
Personally, I was not a fan of the TBSS manifolds. I mocked up a set, but really didn't like the way the driver's side kicked out into the frame(truck in signature). I bought a used set of 2010-15 Camaro manifolds, and love the fitment of those.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 01-22-2021, 08:47 AM   #56
A1971Blazer
A1971Blazer's Avatar
$100 take-offs......2010 Camaro
removed heat shields and smoothed........fit like a glove 67 c10 LS1
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-31-2021, 10:44 PM   #57
1972CST
1972CST's Avatar
A1971Blazer- that's a clean setup you have there. I wound up ordering the TBSS manifolds but I like the looks for yours better.
Old 02-23-2021, 04:05 PM   #58
EagleChief
EagleChief's Avatar
Going to bring this up again...
Anyone know if the 2017 Camaro manifolds will work on a '03 5.3?
Putting a 2003 Tahoe engine into my '71 C10 and found a nice pair of 2017 Camaro manifolds for cheap.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 02-23-2021, 04:10 PM   #59
Ziegelsteinfaust
Has anyone used the Hedman cast manifolds?
Ziegelsteinfaust is offline   Reply With Quote
Old 02-23-2021, 04:30 PM   #60
kipps
Those manifolds will not work. The 2017 Camaro had the gen-5 "LT" engine, and was either the LT1 or the LT4. These had five bolts to hold the exhaust in place, instead of the six bolts that the LS engine used. The exhaust manifold is set up different too, because the ports are in a different position compared to the LS engines.
Old 02-23-2021, 04:34 PM   #61
EagleChief
EagleChief's Avatar
Thanks for the info, although that's a bummer. He only wants $30 for them.
Old 02-24-2021, 11:10 AM   #62
verdell
verdell's Avatar
We installed the Summit Racing brand cast manifolds on my brother’s ‘66 back
in September. Not the Hedman’s but damn near. They fit great and seem to be very good quality also. I can get a pic of them installed later. It’s currently his daily driver, zero issues..
verdell is offline   Reply With Quote
fuvk off
