Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-25-2016, 06:45 AM   #26
PGSigns
PGSigns's Avatar
Re: How far "off" can a chassis be?
Go and read this entire thread and look at the way the chassis and cage was done. Pay close attention to the shape of the bars in the cab and the way they tie to both the front and the back of the chassis. They are done very well and serve 2 purposes. First to give strength to the entire chassis to be able to make it work as it should. You are looking for low 9 second passes on the motor and it takes a good chassis to do that. Second it is there to save your ass if something bad happens. I have wrecked an 8 second car right as it shifted into high gear and hit both walls. It was in a car I built and it held up fine around me. Not so good in the front. There is science, skill and rules that all need to come together to make a racecar (and that is what you are after) go straight, stop straight and save your butt if asked to and what you have along with a few welding lessons is not going to get there.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-25-2016, 10:16 AM   #27
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by team39763 View Post
...Why wouldn't the design work out well? I thought the x was stronger than straight bars?
Read the section (4-11) on roll cage requirements very carefully, so that you don't run into any issues after the fact (particularly the illustrations that note the tubing requirements and for the main hoop support bars). There is also a section specifically on pick up trucks, that I've brought up on this forum whenever someone asks about eliminating the rearward bars from the main hoop.
http://www.nhra.com/UserFiles/file/G...egulations.pdf
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-25-2016, 11:03 AM   #28
ptc
ptc's Avatar
X2 - READ THE RULES before you do work.... otherwise you are just wasting your time and money. The guy that did your rear bars obviously did not know any certification rules, because its ALL wrong.
JMO - The chassis is your whole "FOUNDATION" for everything else that goes on the vehicle. Just like a house being built..... if it aint right then NOTHING will be right.
If your frame is bent to begin with you need to have it put on a frame machine and get it right first before you do anything else.
Good luck
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
