Old 03-30-2016, 08:00 PM   #1
86k30
Front Bumper Question
Are there any differences between front bumpers on the c and K series trucks? I am looking for an original bumper and bumper brackets from a salvage yard to restore for my 87 C10. My local yard has one but it is on a 85 K20. Will this setup fit on my truck? And what would be a good price for these parts?
86k30 is offline   Reply With Quote
Old 03-31-2016, 02:19 AM   #2
andrewmp6
Re: Front Bumper Question
As far as i know they are the same.
Old 03-31-2016, 08:20 AM   #3
Keith Seymore
Keith Seymore's Avatar
The bumpers are the same between an '87 C and an '85 K.
If the air dam is attached they come in three flavors:
2wd - (short) no tow hooks
4wd - (long) without tow hooks
4wd - (long) with cutouts for tow hooks
You can install the long air dam on a 2wd; it will just be closer to the ground.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-03-2016, 05:56 PM   #4
Pontiac1976
Pontiac1976's Avatar
73-80 Frt bumpers more rounder
81-90 Frt bumpers more angler
As long as you work with the same as you have you will be ok
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-04-2016, 11:09 AM   #5
Keith Seymore
By the way: I actually installed those bumpers on the assembly line - for one day.
Part of my co-operative work experience training.
K
1979-1986
1986 - 2019
