Re: Questions About This Paint
If you are concerned about cost [and who isn't] look into some lower gloss[ semi] equipment enamel you can get a gallon for about $30 bucks and sometimes catch it as low as $19.
Or you may want to try some like Omni MP172 and then spray it with a matte clear coat. You can mix some regular clear in with the matte clear to have yourself a customized blend that you can change the gloss level to best suit your needs. |
| Bookmarks |
| Tags |
| flat black, hot rod black, satin black, tcp global |
