Old 04-24-2016, 01:03 PM   #5
Gregski
Gregski's Avatar
Re: Transmission Crossmembers Collect Them All! - 1974 C10
Originally Posted by MikeB View Post
A question: My 82 C10 has a crossmember that's high on the drivers side for exhaust pipe clearance, but low on the passenger side. Will a crossmember like the one above fit my truck for more exhaust clearance on the passenger side? Transmission is a TH350.
I would lean towards saying yes, with the caveat that you may need to drill some new holes in it or elongate a couple, but as far as transmission position it does sit at the same height as your current cross member
but I don't know if there was a big difference in frame design between the 73-80 trucks and the 81-87 trucks so maybe someone else can comment, I always stress that they should have been broken up into two separate eras/generations but no one is listening, ha ha, jk
Gregski is offline   Reply With Quote
