Old 05-02-2016, 11:45 AM   #7
Lugnutz65
Lugnutz65's Avatar
Re: T5 Camaro Tailshaft Swap
Originally Posted by 69rut View Post
You will most likely need to change the speedometer drive gear location on the tailshaft. The gears usually have a clip holding them in place with a hole in the tailshaft as well. You can not drill a new hole and the shaft diameter is smaller where the gear needs to be positioned. Best bet is to shim the gear and use some J-B Weld to hold it all in place.
His 1989 S10 tail shaft housing has a VSS sender. He cannot make the Drive gear work unless he finds an S10 tail housing with cable connection. If he finds one of those, then your advice is correct.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
