Old 03-10-2004, 05:03 PM   #1
dubie
dubie's Avatar
Need some wiring help guys
I hope you 73-87 experts can help me out
I have an 82 Chevy 350 engine in my 72. I haven't fired it yet because it still needs to be wired up. I used to have a 250 inline 6 , so the wiring is totally different. It's a bare bones engine with and HEI. Does anyone have an engine wiring diagram for this engine?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-10-2004, 05:08 PM   #2
Russell
Professional Grade
Russell's Avatar
Any electric options on the engine? If not, its pretty much give 12 volts to the HEI, then 12 volts to the starter and she'll run
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-10-2004, 05:11 PM   #3
dubie
dubie's Avatar
yeah but where does the power to the alternator come from? All my wiring is for a 72 inline 6. The alternator on the inline is on the drivers side and this one is on the passenger side. I have never done much engine wiring in the past.
Does anyone have a pic of their starter with all the wires connected that they could edit and show where the wires from the strater go to?
Old 03-10-2004, 05:13 PM   #4
Russell
Professional Grade
Russell's Avatar
Hmm, not sure about the alternator... My truck is outside in the parking lot, nor will the teacher let me go outside, otherwise I'd go figure it out for you...
Old 03-10-2004, 05:51 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Power comes from the battery to the starter solenoid. Positive wire goes to a junction block (73-87) on the firewall and then goes into the fusebox. That is the switched power wire. Is this what you need?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-10-2004, 06:07 PM   #6
bpmcgee
bpmcgee's Avatar
Alternators could be in either side -- mine is on the drivers side. It depends on if you have a short or a long water pump. And power doesn't go TO the alternator
Brian
bpmcgee is offline   Reply With Quote
Old 03-10-2004, 06:14 PM   #7
dubie
dubie's Avatar
yeah I got that part, but where does the power for the alternator come from?
Old 03-10-2004, 07:02 PM   #8
bpmcgee
bpmcgee's Avatar
The crankshaft turns the alternator via the alternator belt. I don't think I'm understanding your question.
I don't have a diagram here in front of me, but I'll look when I get home where the red wire on the alternator goes. I think that's what you're asking.
Brian
Old 03-10-2004, 07:09 PM   #9
dubie
dubie's Avatar
yeah, thats what I'm asking bud. Just need to know where that wire does to
Old 03-10-2004, 07:18 PM   #10
1FaastC10
1FaastC10's Avatar
Brian
yes, actually it does. it takes 12v for the alternator to start working. you can then remove the 12 volts once it has started charging, and it will continue to feed itself.
1FaastC10 is offline   Reply With Quote
Old 03-11-2004, 02:53 AM   #11
Bowed
The larger red wire on the alternator (post) goes to the + terminal on the battery , to charge the battery and the small red wire (connector) goes to the ignition switch Via the junction block , a thermistor or fuseable link required on that one and the brown wire (connector) goes to the voltage gauge
CORRECTION - Sorry, but I just found out from another thread that I am not completly right on what I posted above , It seems the brown wire goes to the ignition switch and the small red , "well " I don't know I have to find out my self .
Bowed is offline   Reply With Quote
