Old 06-04-2016, 01:37 AM   #1
Bulldog88
I have no throttle responce dbw
I have a dbw that's not working, truck starts and idles fine but i have no throttle,I have checked wiring and made sure pins are in the right spots, changed pedal, tac (pedal box) even throttle body and it won't work, ecm and engine came from 2004 truck. Any ideas?
Bulldog88 is offline   Reply With Quote
Old 06-04-2016, 09:29 AM   #2
clemsonteg
Re: I have no throttle responce dbw
Did you modify the harness or did you put a swap specific harness?
clemsonteg is offline   Reply With Quote
Old 06-04-2016, 01:14 PM   #3
Bulldog88
Speartech did the harness and ecm programming
Old 06-04-2016, 01:36 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Before I blame the tuner (which I will, just not yet).
Scan for codes; are you throwing any P or U codes?
Check the purple and yellow wires off the throttle body, and make sure they haven't pulled out of the connector or broken.
Reset the battery, try again. Do you get throttle response even a *single* time?
Because you said you've replaced parts; where did they come from? Having as closely matched set of TB, Pedal, TAC, ECM, is ideal. If you start throwing parts at it, you can actually ADD problems instead of taking them away. What year did the pedal and tac come from?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-04-2016, 03:04 PM   #5
Bulldog88
The tac and pedal that I put on it came from a 2001 suburban that my brother let me use, I haven't scanned for codes yet
Old 06-04-2016, 04:04 PM   #6
truckdude239
truckdude239's Avatar
2001 did not have dbw , so it could not have been from a 2001 suburban
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-04-2016, 04:53 PM   #7
Bulldog88
Yes it does I'm sitting here looking at the truck 2001 suburban
Old 06-04-2016, 06:49 PM   #8
foamypirate
foamypirate's Avatar
I'm pretty sure an 01' TAC and Pedal will not work with an 04' PCM. You need an 03-05' pedal and TAC.
foamypirate is offline   Reply With Quote
Old 06-04-2016, 10:43 PM   #9
ls1nova71
ls1nova71's Avatar
^^^^^^ This. But I'm 100% sure that the all plastic TAC from a 2002 and older engine won't work with an '04 PCM. You will need a TAC from a 03-05.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-04-2016, 10:48 PM   #10
truckdude239
I guesz im wrong but ive never seen on i service alot of these at work and pre03 all i have ever seen are dbc
David fuller
2000 Tahoe 5.3l 378
Old 06-04-2016, 11:09 PM   #11
72MARIO
72MARIO's Avatar
David...
from what i have seen the trucks and suvs with traction control got dbw there definitely were not many that came dbw. Hope that might explain why you havent seen any. .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-05-2016, 10:15 PM   #12
truckdude239
That would make sense
David fuller
2000 Tahoe 5.3l 378
Old 06-06-2016, 07:49 PM   #13
Bulldog88
Fixed the issue guys, tac module was wrong, I had to go another one so I picked up a 04 model, also there was a faulty wire from the tac to pedal, did some soldering and now it runs like a champ
Old 06-06-2016, 08:05 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Glad you found it. So just so we're clear for guys reading this; the 2001 TAC you borrowed (however unusual) did NOT properly interchange with your 2004 pedal/tb/ecm. Correct?
Then you had a separate issue with the actual tac->pedal harness, as well.
Always frustrating to have overlapping problems.
