06-29-2016, 07:18 AM | #3926 |
Re: What did you do to your truck today? Chapter II
Sounds like ya'll need to come to NC, mine was less than my 2013 car, also, my grandpa had it registered as a commercial Farm truck, which was much cheaper than it being registered as any other type of vehicle
06-29-2016, 02:15 PM | #3927 | |
Well, still, no smog, so it's still worth it.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
06-29-2016, 10:34 PM | #3928 |
Installed filler panels
06-29-2016, 10:35 PM | #3929 | |
07-01-2016, 10:10 PM | #3930 |
Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-02-2016, 09:02 AM | #3931 |
I drove her on her maiden voyage to the local cruise in last eve sans hood. Still have a few odds and ends to finish up in prep for the trip to Louisville for the Street Rod Nationals.
07-02-2016, 09:49 AM | #3932 |
07-02-2016, 11:55 AM | #3933 |
07-02-2016, 02:02 PM | #3934 |
For 66clow, The drop is 5/7, 2" drop spindles and 3" drop front springs and 5" drop springs with 2" lowering blocks in the rear. The truck was vermillion red and white top but has a bad repaint a little darker shade. It had been buffed on before I bought it and needs some extra work . I painted the rockers, latch pillars and below rear glass. I'll try to dull that up a little as well as the top.
07-02-2016, 06:56 PM | #3935 |
Installed new shocks today.
07-02-2016, 10:11 PM | #3936 |
Installed a stall converter, mated the engine and trans, installed new trans pan, Pulled the front clip, Installed the engine and trans, re-installed the front clip and pushed it out side to look at the ride height with weight in it...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
07-02-2016, 10:19 PM | #3937 |
Is this an episode of overhaulin? Couple days left for the reveal. nice work.
07-03-2016, 04:33 AM | #3938 |
Check your upper control arms. There was a thread about being on backwards (right side on left, left side on right) recently. The bump stop is towards the rear. It's a common mistake. You aren't the first and you aren't the last. I just happened to notice in the picture. Just looking out for you.
07-03-2016, 08:31 AM | #3939 | |
07-03-2016, 02:35 PM | #3940 |
Active Member
When I bought my truck just recently, the owner said he thinks the carb needs to be rebuilt, the accelerator pump is dead, and if you romp on the gas, it'll stall. Once I knew more about what was going on (replacing the entire fuel system basically), I figured it probably wasn't just the accel pump, but I figured it needed to be replaced anyways, and the carb is pretty old. It's an Edelbrock 1406. Got a kit on eBay from a place called Carb Junkies, good quality kit, came with new floats and an accel pump with a steel rod that supposedly won't be affected by modern gas. Only $43. I've heard these are an easy rebuild, and it really was. Turned this:
into this: Post cleaning: Reassembled: |
07-03-2016, 08:10 PM | #3941 |
Added power steering to ol Goldilocks.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
07-03-2016, 08:12 PM | #3942 |
Topside photo.
Dam photos are sideways for some reason.
07-03-2016, 08:25 PM | #3943 |
RAT1968 '68 Cab/'71 Parts
Damn! I had to lay on my back to take a shot of the underside of the P.S. pump... Damn...!!!! Hope this helps!
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
07-03-2016, 08:50 PM | #3944 |
07-03-2016, 10:01 PM | #3945 | |
07-03-2016, 10:15 PM | #3946 |
Roll pan and spoiler go great with the super cool hood, getting nothing but better..
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
07-04-2016, 08:46 AM | #3947 |
Thanks. How did you flip em?
07-04-2016, 11:13 AM | #3948 |
07-04-2016, 11:51 AM | #3949 |
07-04-2016, 01:47 PM | #3950 |
Well it was more this weekend then today but I did a 5 lug disc brake conversion, change out the gears in the rear end, lowered the front about an inch more and put on a new set of flat black rally wheels.
