Old 07-28-2016, 12:15 AM   #1
1BAD65
>>>where do i drill hole for diy vented gas cap<<<
CARB IS FLOODING AFTER REPLACING ALL FUEL LINES AND MECHANICAL FUEL PUMP
TANK HAS 2 LINES OUT AND VENT
PUMP ONLY HAS 2 LINES IN (FROM TANK) AND OUT (TO CARB)
BROTHER TEXTED ME TODAY SAYING CARB FLOODED BADLY - GAS EVERYWHERE
TOLD HIM TO CRACK OPEN THE GAS CAP UNTIL I CAN GET OUT THERE TOMORROW MORNING
I SEARCHED ON HERE AND FOUND ALLOT OF GUYS JUST DRILL A PINHOLE IN THE GAS CAP TO TRULY MAKE IT A VENTED GAS CAP BECAUSE THE STORE BOUGHT "VENTED GAS CAPS" DO NOT TRULY VENT BUT HOLD 3psi !
DOES ANYONE HAVE A PIC OR DIAGRAM SHOWING WHERE I AM SUPPOSED TO DRILL THE PINHOLE?
THANKS GUYS
I WILL CHECK BACK TOMORROW MORNING
1BAD65 is offline   Reply With Quote
Old 07-28-2016, 01:15 AM   #2
kwmech
Re: >>>where do i drill hole for diy vented gas cap<<<
If the carb is flooding, you more than likely have a sunk or stuck float. Randomly drilling holes in things isn't going to fix it, and get rid of the caps
Old 07-28-2016, 01:17 AM   #3
Clavo106
Not shure on the gas cap drilling ..but I would check the carb float bowl and check that the needle is seated properly and adjusted right..
Clavo106 is offline   Reply With Quote
Old 07-28-2016, 01:19 AM   #4
Clavo106
Yep x2 my slow spelling. .
Old 07-28-2016, 02:35 AM   #5
TurboThrift
I had a similar problem on my 67..
The cap installed by the PO was unable to vent adequate pressure, resulting in gas forcing itself into the carburetor and eventually into the crankcase.
I used a NAPA cap (p/n: BK 7031220) to remedy this. It worked like a charm! No more contaminated oil or carburetor flooding.
Hope this helps!
TurboThrift is offline   Reply With Quote
Old 07-28-2016, 10:26 AM   #6
1BAD65
@TurboThrift
YOU KNEW EXACTLY WHERE I WAS COMING FROM!
FIRST STOP NAPA !!
THANKS FOR THE PART NUMBER TOO! VERY HELPFUL POST - THANKS BRO
Old 07-28-2016, 10:28 AM   #7
1BAD65
Clavo106 & kwmech
THANKS FOR YOUR INPUT
GOING TO CHECK CARB SPACER HEIGHT, CHOKE SETTING AND FLOAT SETTING AS WELL
