Old 07-31-2016, 05:44 PM   #1
Koz1
Another 2 piece driveshaft angle question
Here are current angles on mildly static lowered 1991 suburban
tailshaft angle -2.6 slope down towards center support bearing
1 shaft angle -3.6 slope down towards center support bearing
2nd shaft -1.3 slope down towards center support bearing
pinion angle -4.8 slope down to ground
all angles as posted have a - slope. Do these fall within range, there's a very minor vibration at 45-85, brand new wheels and tires, even before with the old stock factory wheels,had same slight vibration.
Also those listed angle above are very close to the before lowering of the vehicle at factory height.,lastly vehicle has 64k original,and i've serviced since new.
Koz1 is offline   Reply With Quote
Old 07-31-2016, 06:57 PM   #2
Koz1
Re: Another 2 piece driveshaft angle question
correction
all slopes are negative
2nd shaft angles towards rearend
pinion angle point's up so it's negative as well
using the spicer operating angle app
operating angle 1 is 1
operating angle 2 is 2.3
operating angle 3 is 3.5
do these angle's seem to be allright
btw- u-joints all tight,center carrier bearing no play,axle bearings,rearend,all ok.
Old 07-31-2016, 09:30 PM   #3
clemsonteg
I've always been told that the angle should be kept within 1 degree to minimize driveline vibration. Sounds like your rear end needs to rotate up a few degrees
clemsonteg is offline   Reply With Quote
Old 08-01-2016, 10:59 AM   #4
SCOTI
SCOTI's Avatar
Deleted.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-02-2016, 07:00 AM   #5
clemsonteg
Originally Posted by SCOTI View Post
Deleted.
Deleted because you planned to say something similar or deleted because it's a complicated subject? Just want to make sure I stated it correctly.
Old 08-02-2016, 08:48 AM   #6
SCOTI
SCOTI's Avatar
While the Spicer info is correct, if you ask anyone w/knowledge on the subject, as soon as the rear-end is higher than the other driveline parts the numbers yield different results.
The best results I got w/my dually was aiming the rear pinion toward the carrier bearing while not keeping it straight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2016, 07:12 AM   #7
clemsonteg
Totally agree. 2 piece shafts are a little different than 1 piece shafts too. I think mine right now is around 5 degrees down on the tailshaft, 2 degrees down on the drive shaft, and the rear end points up around 5 degrees. It works, but I want to make it a little better. I read a ton of articles when I was setting it and probably confused myself more, but what I took from it was try to have similar angles on u joints and and have the trans and diff point opposite directions at similar angles (trans is pointing down as it points toward rear end and rear end is point up toward trans)
Old 08-03-2016, 03:25 PM   #8
SCOTI
SCOTI's Avatar
So, lets make sure we're all on the same visual here....
The trans tailshaft is sloping down (higher @ the front of the vehicle vs rear (normal).
The main shaft is again higher @ the front/trans output vs the rear/carrier bearing (normal).
Is the secondary shaft higher @ the front/carrier bearing than the rear/pinion joint (normal) or higher @ the rear than the front (not normal)?
Is the pinion (@ the u-joint) pointing up toward the sky or down toward the ground?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2016, 08:05 PM   #9
Koz1
tailshaft down 2.6 toward ground
first shaft down 3.6 toward carrier bearing/ground
2nd shaft down 1.3 toward ground/rearend
pinion 4.8 pointed up to sky
thanks, i tried to edit very first post to make it simple but it wouldn't let me edit,i'm guessing there's a time lock after a post?
