Old 08-30-2016, 10:20 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Proper names of frame sections?
Can anyone identify or know where to locate them? For example the core support sits on the blank portions of the frame..............They'd come in handy as I take notes of the rebuild. Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-30-2016, 10:50 PM   #2
leftybass209
leftybass209's Avatar
Re: Proper names of frame sections?
Looking through the GM manuals, there isn't a specific name for any portion of the frame rails. It's pretty generic: chassis, frame, crossmember, brace....
leftybass209 is offline   Reply With Quote
Old 08-31-2016, 12:29 AM   #3
71CHEVYSHORTBED402
I did look first. Came up empty.
Tony
Old 08-31-2016, 02:52 AM   #4
FirstOwner69
FirstOwner69's Avatar
As Lefty said, there is no standard. So, do whatever suits you. As an example, number them as a reference. #1 could be from the front bumper to the front cross member. #2 could be from the front cross member to the firewall/front of cab. #3 from front of cab to back of cab. #4 from back of cab to rear axle. #5 from axle to rear bumper. You can then assign letters within each section if desired. As an example, 1A could be the core support location. Draw sketches if it helps for further definition.
FirstOwner69 is offline   Reply With Quote
Old 08-31-2016, 02:52 PM   #5
71CHEVYSHORTBED402
I give up, what's the cross member?
Tony
Old 08-31-2016, 06:03 PM   #6
Grumpy old man
Grumpy old man's Avatar
The core support sits on the frame HORN section , relate frame sections to the corresponding parts bolted to it . front suspension , engine ,trans ,trailing arm ,spring perch ,rear bed support ...
Old 08-31-2016, 06:26 PM   #7
hugger6933
The crossmember is and does what it sounds like. That is a member that crosses from one rail to the other no matter the job or location say you have a front crossmember, pretty straight forward it goes at the front. The trans crossmember holds up the trans. some cross members have nothing bolted or riveted to them and the are just for structural support.
hugger6933 is offline   Reply With Quote
Old 08-31-2016, 06:27 PM   #8
71CHEVYSHORTBED402
Ah, making sense. Thanks a bunch for the responses.
Tony
Old 09-01-2016, 07:58 AM   #9
The frame horn's connected to the... engine rail.
The engine rail's connected to the...
