Old 10-12-2016, 07:19 PM   #1
elks
Fuel Tank? Aerotank? Other?
So I have been searching. At one point I was heading towards a Northwest Fab tank. But they no longer make tanks. I see that Aerotanks make a 40 gallon tank.
I am running throttle body injection on a 5.7 with an external pump. No big deal.I want to get to 30+ gallons as I am always hunting and it gets old packing gas everywhere.
I see where some say you can use a 87 tank, but I really want a full write up. I am not against having a custom tank built if I just had good dimensions. The PO on my blazer used a 16 gal fuel cell. Does not make it too far from home.
So links to an aerotank install, or a late model tank install. I want to keep my factory fill location.
I have found several threads with bits and pieces, but not a complete build thread.
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 10-12-2016, 07:24 PM   #2
jondancer
Re: Fuel Tank? Aerotank? Other?
Boyd welding .
jondancer is offline   Reply With Quote
Old 10-12-2016, 09:39 PM   #3
elks
So does anyone have a set of drawings they sent Boyd? I am not sure how much detail they would need. Will they end a tank with sending units fuel pump, etc.?
Old 10-12-2016, 09:51 PM   #4
T'S1972
http://www.fueltankparts.com/replace...ks.html?cat=61
T'S1972 is offline   Reply With Quote
Old 10-12-2016, 10:23 PM   #5
elks
Originally Posted by T'S1972 View Post
The tanks look great. I a, wanting to increase volume to 30 almost 40 gallons. The pre made fit tanks there all read 19 gallons. I will give them a call and see if they have a tank plan for something above gallons!
Old 10-12-2016, 11:11 PM   #6
72 paul
Why not areo.There a good tank,40 gal or just about anything you need. Ialmost sold one but glad the deal fell thru.Mine bolted through the bed.Ibelive thay do a different one with flanges and bolt to frame.I may get rid of the bolt thru body on mine yet,but am going to reuse it as need some mods anyway.Only filled it all theway up twice in 5 yrs of driving truck.
72 paul is offline   Reply With Quote
Old 10-13-2016, 10:27 AM   #7
elks
That is the direction I am leaning! I wish I had a few pics or install thread. I am just concerned about ground clearance in a blazer. Like I said my buddy did one of the northwest 37 gallons but they are no longer being made!
Old 10-13-2016, 03:59 PM   #8
wannabefastcrf
91 blazer tanks are like 31 gallons. it isnt to hard to retrofit them. i did one for my LS swap
wannabefastcrf is offline   Reply With Quote
