#26 |
![]() Join Date: Feb 2016
Re: Do you replace or reuse rusty hardware?
The problem with dipping them clean like that is that you're not restoring the corrosion resistant coating. You have to be sure and follow up with some other product to prevent quick re-rusting.
#27 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#28 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#29 |
Thank you for the info. Noted and I'll call for certain.
#30 |
Are http://www.kaehr.com/ the guys that did that box of parts for under $50?
I do my own tumble-clean-buff-zincplate passes at home with an Eastwood plating kit, but if I could have done them in bulk, I would have!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#31 | |
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#32 |
Its my understanding that the plating shops located in states along the border have the work done in Mexico where environmental concerns are non-existent, and labor is cheap. Same goes for the paint shops.
#33 |
Carpe manana
The minimum charge at Kehr exceeds $50 but other operations may have lower minimums. Kehr is a decent sized outfit and does the work locally here in new not old Mexico. There's at least one other local outfit here as well.
#34 | |
What I have been doing may or may not be the best, I'm still new at this. I don't think any of my bolts have really rusted, it was the parts they were holding together that rusted. Anyway, I spray all bolts, nuts, washers with NAPA Rust Treatment (Permatex). I have no real experience with how it performs as a rust preventer, but I did leave some fasteners outside once after spraying and they were rained on over night. No rust the next day. |
#35 | |
Concerning stripped parts rusting out, I'd say that depends on environment. I began stripping parts and even the frame 10 months ago. There's no visual rust. My bed has been stripped for 5 years. It's never seen water. Unless you can convince me metal can rust from the inside out, at worst it needs a little sanding. Like the OP, I'm no expert. At best I wipe parts down with oil, then store em away. I'll hit them again before refinish of course. Probably a good idea to soak the parts in vinegar beforehand, but if I have the small parts plated, then I don't have to do anything.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-11-2016 at 01:09 AM. |
#36 |
If you don't mind me asking, what company do you use for the plating?
"Negative people always seem to have a problem for every solution" |
#37 | |
http://www.arrowplating.com/ Last edited by Shady Rascal; 05-11-2016 at 05:53 PM. |
#38 |
Thanks, I will check them out.
#39 |
Shoot, for a dollar per pound I wonder if I could ship them stuff?? There's nowhere around here that would touch that price (or even plate small stuff..)
#40 | |
If I contact them and get an answer Ill be sure to post up what they say about shipping stuff in. |
#41 | |
![]() I wish I had found out sooner but this is a learning process on my truck. |
#42 | |
HO455
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#43 | |||
"I ain't nobody, dork."
Gary
#44 |
I called a local (well, 3 hours away) plating shop and they can do everything for about $130.00. Dang, we need some illegal labor!
![]() I am thinking about it. My biggest fear is I won't remember what bolt goes where. Maybe I can sort it all out into different types and keep pics, we'll see. The plating guy suggested a cadmium-gold plate. Thoughts? |
#45 |
Carpe manana
Grab a dry erase board and a digital camera and take pics like I'm doing: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 (scroll down).
In the last month I've had two big batches of clear zinc done. The washer fluid nozzles look absolutely brand new. Cadmium what was cadmium lest that hardware look funky.
#46 |
![]() Join Date: Jan 2015
Anyone have pics of what the different coatings look like?
Jimmy Hoelzel |
#47 |
![]() Join Date: Jul 2015
#48 |
Carpe manana
See post #s 10, 16, and 18 above...
#49 |
Take things off and put in labeled jars of vinegar. Leave it overnight or even a couple days. Any oxidation will wipe off.
Take the parts out and rinse them off, then figure out if they're reusable. If not, make a note and look for it the next time out hunting. The usable stuff can be refinished by sticking the bolts on cardboard, put nuts hanger wire (spaced out), and hang the other parts on hagers with thin wire. Two or three light coats of paint work a lot better than one thick coat. This method isn't as easy as ordering everything new, but the factory parts quality is much better than the shiney new repop stuff. |
