1978 454 missing/backfire
I have a 1978 454 that seems to have a bit of a hesitation and a little backfire out of my exhaust? I've been fighting this for a few weeks now. I have replaced wires, cap, rotor, plugs, vacuum advance... I can't seem to find the problem? It makes a slight squeel that sounds like it's coming from #1 just as it sends out a little backfire through the exhaust? Does anybody know what this might be?
Posted via Mobile Device |
![]() Join Date: Jan 2011
Re: 1978 454 missing/backfire
First thing I would do is a compression check. Have you pulled the valve covers to look to see if all the rocker arms are moving like they should? Motors need three things, fuel fire and compression. Looks like you have just worked on fire.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I will get on it ASAP and let you know! Thanks Jimmy!!! What compression should I expect? It's had a little head work, headers and a small cam. All done prior to me getting it.
![]() Join Date: Mar 2013
A slight pop out the exhaust could be ignition, valves to tight and/ or not seating, weak springs, flat cam lobe, and a/f ratio wrong. Before the compression test I'd adjust the valves. Any that are to tight will cause a miss because the valve is hanging open. Far as the numbers to look for I don't know for a bbc.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#6 | |
Okay, I checked my plugs and the gaps were at about 60. Is that normal? I re gapped them to 47. Also, my timing seems to be jumpy? What causes that? My vacuum advance is new and working fine. I can't bind any other vacuum leaks? This thing starts right um and after about 2 minutes sets at a steady idle of 550-600 but as soon as I try to give it any fuel it has hesitation and continues to hesitate even at a steady speed? If I'm rolling down the road at 25mph holding it there it's slightly jumpy and when I give it gas it's even a bit worse with the hesitation? Anything helps...
Maybe just a lack of initial timing!
What's your timing curve like? |
#10 | |
| Bookmarks |
