![]() Join Date: Jan 2015
Anyone know if this part is available ?
This is the plastic spacer/bearing that goes on the bottom of the shifter base on a 64 steering column. It keeps the inner shaft center and supported at the top of the column. I have checked several catalogs etc with no luck. Any help appreciated.
Re: Anyone know if this part is available ?
Another photo
Try these guys www.steeringcolumnservices.com When I needed a rare part for a Caddy tilt/tele column, they had it.
#4 | |
Maybe that is specific to the manual shift because I don't remember seeing that in my 66 w/auto. I just bought a new turn signal assembly and it has the bearing which supports the steering shaft.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
#6 | |
Copy that, I have a upper shaft bearing . The part I'm seeking supports the inner shifter tube. With out the part there is serious play and wobble in the steering column. It's a plastic part and I'm sure they get brittle and break over time. Thanks for the reply |
#7 | |
![]() Quote:
![]() Sam |
#8 | |
Is this on a 3 speed manual shift or automatic?
