Old 01-17-2017, 04:20 PM   #26
Deer_hunter_088
Deer_hunter_088's Avatar
Re: Need Help Dont No What Else To Do
Originally Posted by C.20 View Post
hm i didnt think of that it is a offbrand distributor
had an atv that did that, but the coil sparked bc of stator position, and it jumped timing, and it did EXACTLY what yours is doin. jumped like 3 teeth. pull dist and check On that style of atv, a lil raised pad acted as the rotor on your dist, so when it struck a certian point it fired, when the timing jumped, the valves would open at the wrong time, so it sparked wrong and ran like CRAP at idle, get up in rpms and it went away, but was a lil down on power.
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 01-17-2017, 04:48 PM   #27
volksworld
ok the backfire...is backfiring out the exhaust or popping back through the carb? back through the carb is typically a lean condition...what carb is on it? its possible that while cranking it when it was wet it crossfired and spit back thru the carb and damaged something...blew off a vacuum hose, damaged pcv valve or hose, power brake hose, carb gasket etc...now that its dry its running lean...also did you check the timing? if its way off or all over the place the timing chain could have skipped (original style plastic tooth ones were famous for that)...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 01-17-2017, 06:12 PM   #28
Alex V.
Alex V.'s Avatar
What about the coil? I had similar symptoms after running my '85 out of gas - replaced everything but the coil (the fairly expensive part) and rebuilt the carb. to no avail, but IIRC a new coil fixed it right up.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 01-17-2017, 06:24 PM   #29
C.20
C.20's Avatar
Its a demon and we bought a new carb also and we checked the timing and it was fine
C.20 is offline   Reply With Quote
Old 01-17-2017, 06:24 PM   #30
C.20
C.20's Avatar
Put a new coil in it
Old 01-17-2017, 08:01 PM   #31
67 chevelle
67 chevelle's Avatar
check timing before you do anything
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-18-2017, 12:40 AM   #32
C.20
C.20's Avatar
Originally Posted by LongBox View Post
A backfire strong enough to blow a muffler means unburnt gas was in the exhaust. this is because the engine was turning, but not firing. When it started firing again, the hot exhaust ignited the unburnt gas in the muffler. We used to do that on purpose when we was kids.
Since the last thing worked on seems to have been the ignition, time to go over the distributor very carefully, in an organized way. Is the wire from the coil connected correctly? Is the rotor seated on the plate on the top of the shaft. Is the centre contact in the cap there, and in good order. Is the centre contact on the rotor in good shape. I know these are new, but they can get out of whack.
Next, is each plug wire firmly seated in the cap? And at the plugs? Are the wires in good shape, with no issues with the insulation? Etc.Etc. Etc.
will check on this tommorow im running out of ideas
Smoke Tires Not Drugs
Old 01-18-2017, 01:06 AM   #33
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Bad distributor is my guess.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-18-2017, 01:33 AM   #34
dmjlambert
dmjlambert's Avatar
I read through the thread and don't think you mentioned yet, are you powering the HEI distributor with the stock resistor wire, or have you done the 12V solid wire modification to your wiring when you installed the HEI?
Old 01-18-2017, 01:48 AM   #35
C.20
C.20's Avatar
thats what im thinking
Old 01-18-2017, 01:50 AM   #36
C.20
C.20's Avatar
pulled the first plug cranked it till it shot out of first looked at the rotor and it was pointing to number one
Old 01-18-2017, 01:50 AM   #37
C.20
C.20's Avatar
i did the mod to 12v
Old 01-18-2017, 08:22 AM   #38
67 chevelle
has almost nothing to do with timing , check your timing
Old 01-18-2017, 10:50 AM   #39
C.20
C.20's Avatar
I can't test it with a light because it doesn't have a mark were you can check it with the light
Old 01-18-2017, 11:31 AM   #40
C.20
C.20's Avatar
So took the truck out this morning and when it shifts or gets to a certain rpm it backfires when I keep it at that certain rpm it backfires ALOT
Old 01-18-2017, 11:35 AM   #41
C.20
C.20's Avatar
Old 01-18-2017, 11:47 AM   #42
geezer#99
geezer#99's Avatar
Sure it does!
Clean off the balancer and find it.
THen check where your timing tab is. It'll be at 2 oclock or at 12 oclock. At 12 oclock you need to look behind the water pump for it.
geezer#99 is online now   Reply With Quote
Old 01-18-2017, 10:27 PM   #43
71CHEVYSHORTBED402
Now there's a good starting point.
Let us know what it is OP.....Thanks
Tony
Old 01-18-2017, 10:37 PM   #44
firedemon
had a 74 monte carlo with a 350 it had a bad cam and it backfired through carb and exhaust had 3 or 4 bad lobes on it at 85 thousand miles . not saying its it but if all else fails something else to check
firedemon is offline   Reply With Quote
Old 01-19-2017, 08:37 PM   #45
Steelheader
Steelheader's Avatar
I had a similar situation last year , thought I fouled a plug so I did a tune up ( plugs and wires ) still same issue , replaced cap and rotor still the same issue , started looking into everything and I couldn't figure it out , and I tried evething before tearing into the internals , so for the hell of it I pulled all the plugs and found one that wasn't firing (new plug )replaced it with another new one and it fired right up no more issues , so it is possible to buy bad new parts .
I would also double check the to make sure all your plug wires seated properly , I've seen that multiple times . I like to feel a nice solid snap , and if it's not squeeze the connector down with some plyers for a good fit .
Just a few suggestions , probably stuff you already tried , but I know how frustrating things get , some times the easiest fix is to take a step back and let some fresh eyes take a look at it , might be something stupid . Good luck .
Sincerely, Doug
Steelheader is offline   Reply With Quote
Old 01-20-2017, 12:11 AM   #46
dmjlambert
dmjlambert's Avatar
Originally Posted by Steelheader View Post
...I pulled all the plugs and found one that wasn't firing (new plug )replaced it with another new one and it fired right up no more issues , so it is possible to buy bad new parts .
How did you do the test to determine it wasn't firing?
