Old 01-30-2017, 07:34 PM   #1
Mav
Mav's Avatar
70 K10 blower motor
Anybody ever remove the bottom screw in less than 1/2 hour w/out taking inner fender off?
Mav is offline   Reply With Quote
Old 01-30-2017, 08:49 PM   #2
custom10nut
custom10nut's Avatar
Re: 70 K10 blower motor
It's easy when you take the hood hinge loose and prop ithe hood up out of the way.
custom10nut is offline   Reply With Quote
Old 01-30-2017, 09:24 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: 70 K10 blower motor
Wait until you have to take the whole heater box out!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-30-2017, 09:42 PM   #4
saxart
saxart's Avatar
You could always do the same thing the PO did to my truck's inner fender...
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 01-31-2017, 12:35 AM   #5
RB72
That was the best way I found to do it!
RB72 is offline   Reply With Quote
Old 01-31-2017, 12:57 AM   #6
CG
BlahBlahBlah
Looks like a fun job, mine is starting to howl now and then. Add it to the list haha.
Old 01-31-2017, 08:06 AM   #7
Mav
Mav's Avatar
Hadnt thought of that saxart, but think I will wait till I have reason to take inner fender loose and put bottom screw back in...
Old 01-31-2017, 08:32 AM   #8
chiefcfd
chiefcfd's Avatar
I have taken the inner fender loose and done this. It was my 2wd though. Looking at the hole in saxart's post you could drill a hole and plug with a rubber plug.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
