Old 02-06-2017, 11:13 AM   #1
jsera
Correcting Chevy Lean on my 72
Hey guys one of the issues Ive had putting the truck back together is the infamous chevy lean. I sit one inch higher on the passenger rear but the front is level. Can I just install a 1" lowering block on the passenger rear between the axle and trailering arm?
jsera is offline   Reply With Quote
Old 02-06-2017, 01:22 PM   #2
demian5
demian5's Avatar
Re: Correcting Chevy Lean on my 72
Sounds like too many launches at the local drag strip tweaked the chassis or frame.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-07-2017, 09:11 AM   #3
jsera
Do I HAVE to go to a frame shop? That just sounds expensive...
Old 02-07-2017, 11:13 AM   #4
Toms67
Toms67's Avatar
Are your springs in good shape? I would rule everything else out first. Sometimes one spring might be weaker than the other.
Toms67 is offline   Reply With Quote
Old 02-07-2017, 12:39 PM   #5
jsera
The entire suspension is brand new
Old 02-07-2017, 11:55 AM   #6
hayhauler71
hayhauler71's Avatar
Subscribed for more info on this. I found on mine to measure the spring under load to the other rear spring. Mine was 3/4 shorter compressed. Tried new springs with same results. Added 1 inch steel block on top of spring and was perfect also no more rear wheel hop on hard launch.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-07-2017, 12:58 PM   #7
jsera
If you put a spacer on top of the spring that would have raised the truck? so you raised the driver's side to match the passenger?
Old 02-07-2017, 01:35 PM   #8
hayhauler71
Correct
Fuzzy
Old 02-07-2017, 01:57 PM   #9
jsera
Correct
I guess its the same thing, Im just lowering the passenger to match the driver instead. Im going to lowes for some large washers later to accomplish this as the 1" lowering block I bought yesterday wasn't long enough to go across both legs of the u bolt.
Old 02-07-2017, 03:18 PM   #10
67 chevelle
67 chevelle's Avatar
I had the same issue , I put a 1 inch lift ring under the drivers coil spring
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-07-2017, 11:56 AM   #11
onebigjohn
onebigjohn's Avatar
There are shops that RE-arc and DE-arc springs....Careful Check the shops work this is an ART not a Science.
Each leaf is done individually by hand on a press
Check the shops that have been around for 50 years
"I pawned my Hanso"
"Hold my beer, Watch this"
onebigjohn is offline   Reply With Quote
Old 02-07-2017, 12:41 PM   #12
jsera
its a coil spring setup so I'm not sure this would apply?
Old 02-07-2017, 01:02 PM   #13
onebigjohn
onebigjohn's Avatar
You are correct.....Never mind.
"I pawned my Hanso"
Old 02-07-2017, 03:22 PM   #14
Ekliptix
Ekliptix's Avatar
I'm told it's not uncommon for these trucks to sit slightly uneven left to right. It was the case with mine after I installed new (ECE) coils. A 1/2 block under one of the rear coils corrected it for me.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 02-07-2017, 11:47 PM   #15
Sklptrljay
Sklptrljay's Avatar
My 2 cents.....
I was distraught after putting in all new ECE suspension and found my truck leaning pretty hard. I lowered it 6" so it was even more noticeable than before.
My cousin is a body guy, and he was able to find the spot on the frame that was tweaking the truck. We jacked it up, and put a jackstand in that spot and let it sit overnight. It went from an inch and a half off to less than a quarter inch.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
