Old 02-03-2017, 12:31 PM   #76
gmachinz
Re: Power Window Relay Mod?
There's a few ways to do it. If it's something you plan to tackle, there are a myriad of diagrams all over Google showing how to do it. I don't do it the typical way since I like to convert to a ground trigger but that involves modifying the switch connector leads itself and it is better to go with a new harness in a lot of cases then....and that allows for nicer upgrades like auto down, etc. and while a basic relay splice kit will work, there are a few ways to do it. I'd say look for a diagram you're most comfortable doing yourself....kinda hard to suggest how since a lot of my components are commercial grade and not found in any of your typical places.
gmachinz is offline   Reply With Quote
Old 02-03-2017, 02:00 PM   #77
4x4chase
Originally Posted by gmachinz View Post
Those are junk....but they will prolly work....for awhile....keep a fire extinguisher handy lol
Do you have ones you would recommend?
4x4chase is offline   Reply With Quote
Old 02-03-2017, 02:05 PM   #78
gmachinz
I do depending on what you'd like to do. I have:
Relay splice kits for stock setups
Relay splice kits w/auto down
Relay splice kits w/auto down/up
Full replacement harness with or w/o ground trigger and still the previous listed options.
Old 02-03-2017, 04:14 PM   #79
4x4chase
Just regular relays you have found reliable.
I like the auto up and down but that takes some wiring changes Im not sure Im up to.
Old 02-06-2017, 07:31 PM   #80
jon9116
Well I got it all wired up properly but got no power. I used the pink wire from the switch as my power source to both relays. From switch, brown and blues to 85 (both relays) and from the motor brown and blues both to 30. Tied my grounds together 86 and 87a on both relays to one ground wire. I go to test and nothing happens. My ground from the relays were drilled into the door. Am I missed something? Do I not have an adequate ground from the switch?
jon9116 is offline   Reply With Quote
Old 02-09-2017, 08:04 AM   #81
Skunksmash
Skunksmash's Avatar
How much are you asking for your rely splice kits, with Auto up/down?
Also, does anyone have any idea just how much faster the windows actually go, once you have them hooked up to relays? Anyone have a video? Is it really worth the trouble? Or is it only a slightly noticeable increase in speed?
Skunksmash is offline   Reply With Quote
Old 02-09-2017, 11:02 AM   #82
gmachinz
Time wise with all your door hardware in good shape, on average the relay mod knocks the time in half or slightly more-then add autondown and it's like having a new truck-it's something people never notice unless they suddenly don't have that feature then they're like wtf? lol
Old 02-09-2017, 01:06 PM   #83
83GMCK2500
I posted a video in Post #13 of this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=717227
They're much faster. Much.much.faster.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 02-09-2017, 01:15 PM   #84
FB85C10
gmachinz how much for a 2 window kit, i have power windows already, shipped to NJ.
FB85C10 is offline   Reply With Quote
Old 02-09-2017, 01:35 PM   #85
gmachinz
PM sent!
Old 02-09-2017, 01:36 PM   #86
gmachinz
PM sent!
Old 02-10-2017, 06:12 PM   #87
tanman722001
tanman722001's Avatar
Does anyone have a diagram to follow for each door?Already have everything to do it just need to know what wire gets used and where they go. Thanks
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 02-12-2017, 09:29 AM   #88
tanman722001
No one has a wire diagram for this mod for these trucks??
1990 Chevy S10
Old 02-14-2017, 08:07 AM   #89
Skunksmash
Skunksmash's Avatar
PM sent!
PM sent!
Old 02-17-2017, 08:35 PM   #90
aussie87
aussie87's Avatar
pm sent
Andy
1979 Corvette
1987 Stepside
2012 Holden Calias
aussie87 is offline   Reply With Quote
Old 06-13-2017, 03:21 PM   #91
MichaelShoe
gmachinz, please check inbox.
MichaelShoe is offline   Reply With Quote
Old 06-13-2017, 06:56 PM   #92
aussie87
aussie87's Avatar
I have also sent you a pm and an email regarding the replacement harness, please reply.
Andy
1979 Corvette
1987 Stepside
2012 Holden Calias
Old 02-28-2018, 02:53 AM   #93
Steve Van Gent
Steve Van Gent's Avatar
Here is a solid state version I installed on my kids 91 K5 Blazer (same as 73-87 C10) that does normal button control of power windows, also one-touch express up/down for both drivers and passenger windows (only from drivers buttons, would take 2nd module to do from passenger side), Also with wireless receiver and Key Fob for power door locks. No mods to switch are required, only cut wires and insert this in serial. Is 20V tolerant so no issue with weird rewiring.
https://www.youtube.com/watch?v=Jo7a...ature=youtu.be
Sorry about wiring mess, was in hurry. Notice the window regulator bolts were loose. Seems common, same on passengers side.
It is 30 amp rated per module and CAN bus enabled (I am not using this), has 6 differential drives and 7 input channels, and only measures 2.5x1.6x2.6 inches, and is 6 oz. has both timer for express up/down and current sensing for min/max/obstacles.
Module is not yet released, I am beta testing for them. I will keep forum posted.
Steve Van Gent is offline   Reply With Quote
Old 02-28-2018, 08:00 AM   #94
GMC Guy
GMC Guy's Avatar
Sub’d for modern touches
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-28-2018, 09:21 AM   #95
gmachinz
Here’s some random pics and install images showing placements of components-the auto down/up kits can be wired as splice harnesses or integrated into full replacement harnesses. Often, the switch connector wiring is suspect as is the wiring going through the cab/door boot into the kick panel area-I have solutions for all of that.
Old 02-28-2018, 10:10 PM   #96
Goats86
pm me please, 86 c10, need a kit, basic, mine are very slow,
Goats86 is offline   Reply With Quote
Old 02-28-2018, 10:55 PM   #97
gmachinz
PM sent!
Old 03-01-2018, 10:29 AM   #98
GMDad
GMDad's Avatar
Did mine last month. Work better. Pretty easy kit to install, comes with all the terminals and connectors you need.
GMDad is offline   Reply With Quote
Old 04-19-2018, 03:50 PM   #99
dieseltech619
I sent payment for my kit and have pmed you twice but have not heard back. Please respond to one of my messages. Thank you
dieseltech619 is offline   Reply With Quote
Old 04-19-2018, 09:18 PM   #100
bennylava
bennylava's Avatar
I'm gonna do this!
But does anyone know of a good fuse block to place under the hood, next to the battery? I'm going to have too many wires all trying to be attached to the battery. I need a fuse block so I only have to have one extra set of wires going to the battery.
Preferably a fuse block where you have some room to write a little label on there, so you know what wire is used for what.
bennylava is offline   Reply With Quote
pm sent
