question about lowering the front
Hi guys, I have a 84 C10 that I want to lower some. Thinking about 3 inches in the front, My question is which why have you guys done this spring or spindles? Thanks in advance
1991 GMC K2500 4X4 350/auto 1991 Chevy S10 ext cab. 1990 Chevy S10 1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto |
Re: question about lowering the front
I think drop spindles 2.5 or 3 inches should be the first step in dropping it. Then if you want it a bit lower you can trim your springs if they are not wore out or get lowering springs to make up the difference.
Spindles are the best way as it leave all the stock geometry in place. However, some 3" spindles can interfere with smaller wheels. I personally prefer 2.5" spindles and cutting 1 full coil from stock springs (approximately 2") for a total of 4.5" drop, and matches the axle flip kits perfectly IMO.
I have 3" spindles. Get 2.5" spindles.
And yeah - cut that coil too.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
78C10 short step...I flipped the back, and put 2.5" spindles on the front, with 2" springs. My truck has a little rake to it, and the tires rub on the inner fenders occaisionally...if i did it again i would use the 2.5 spindles, and probably just cut a coil off my stock coils...
Diggin The SquareLife
Get spindles over springs as spindles lower the body an springs changes geometry of suspension etc
Curious why you suggest 2 1/2 over 3" spindles?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
As I understand it:
- You won't likely need to clearance the lower control arms to fit 15" rims (as I did). - Less (or none) of the lower control arm hanging below the rim (not usually legal).
Makes sense. He never said what size wheels so I wasn't thinking about that. Western chassis spindles claim to work with 15" steels and 3" drop. Can't speak on laws though.
the only spindle that works with stock rallys is the western chassis I had them on my 84 all other spindles u have to clearance the control arm
I want to run stock rally for know. I want a little rake don't like them sitting level. By cutting stock spring does it make it ride any different? and how low can the rear go without a c notch?
I don't think you are going to need a notch at all. The pumpkin hits the bed floor before the axle tubes hit the frame.
I notched mine when I shortened the frame and flipped the axle, and I think notching the frame is a waste of time. And I ~haul~ things in my truck - the tubes don't hit where the frame used to be. (although, on a hard turn, it's possible the tube might touch as the chassis rolls - lower it first, and decide later). I did need shorter shocks even despite shock extenders, as the shocks were bottoming when fully loaded. I used 4WD front shocks in the back with the extenders I fabricated.
Ok only 2 brand spindles will clear...
#15 |
Dont cut the stock spring...it will ride like crap....when ppl cut springs they buy stock big block springs an cut them an the ride is great. An u can go low as 6" in rear with no notch as long as u dont haul or tow anything
#16 |
#17 |
I can verify belltech and mcgaughys spindles cause the rally wheels to rub on the lower control arms. It's not that you can't use these spindles with rally wheels, you just have to trim the lower control arms. Not a big deal
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU Last edited by UKNOWME; 02-12-2017 at 03:08 AM. |
#18 |
ok Thanks guys. I'm just not sure how low to go. 3 front 4 rear or 4 front and 5 rear
#19 |
Not trying to be argumentative but that's not true, either.
I did about a dozen trucks that way, back in the day (plus my Chevelle). Cut two coils on the blue truck. Cut one and a half coils on the red truck. It has been a daily driver for 30 years and a quarter million miles with no issues. It is the most comfortable vehicle I own. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#20 |
I cut coils when in high school, and it works but I thought it made the front bounce more as the top coil is no longer a larger flat surface...
I followed bbc10s advice and I used a 2.5" western chassis spindle and 2" coils and a belltech rear 6" flip. If you want that low, that's the setup to use. Keep in mind mine has very little travel, like 2" in the front and rear before I'm hitting rear frame and front stock bump stops and front inner fenders. No fat girls, or three wheelers in the bed though. It works for weekend strolls... As far as 15" wheels, the 2.5" spindle only clears the inside rim edge by 1/8", I had to cut off the clipped on wheel balance weights. ![]() |
#21 |
Looks great!!!
#22 |
Rottenwood Garage Member
As mentioned above, most drop spindles will have slight clearance issues with 15" wheels if you are going to run them. I ordered some early classic ones a few months ago and the tech department said they did not rub.....GUESS WHAT!
2.5 drop spindles and 1" cut coil is the way I went.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#23 | |
Also, what sizes are your wheels? I like that stance! I haven't dropped my 84 yet so I'm still doing my research. Rob |
#24 |
I used western chassis coils. Belltech shocks. No shock extenders in the rear. Bought the notch. But didn't cut the frame yet. It does probably need to be done. But I haven't looked at the rear diff to bed clearance. The tires in that pic were 255/70/15 with 15x8 stock wheels. But now it has 20x9 all the way around with 255/45/20 and 295/40/20. Looks good. I wouldn't say it drives great as every good dip bottoms me out. Not sure if different shocks would be better or worse. But I did like the western chassis spindles. Just had to finish tapping out the dust cover bolt threads. And belltech has always been good on the flips. Avoid DJM.
My truck dropped about 4.5/6.5. And measures now 27" from ground to center of fenders. Tires were and are still 29" tall. |
#25 | |
Romans 10:9 - The Truth |
