Re: 1966 C10 Project Truck
Looking good Scott!
When are we doing an LS in the '69??
LS in that would be sweet! Sean and I will have it figured out by the time you're ready
Lovely no the second to last pic in post 232.
Progress is always progress.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
Here's the weekend update. Friday night, the pushrods and rocker arms showed up so I got those installed. I was a little apprehensive about this job because I had found 3 different methods to install them and horror stories from each method. I took my time and everything turned out just fine.
![]() ![]() After that, I went and picked up the fuel filter setup and headed over to a friends house, he wasn't home but his neighbor was so I stopped in and ended up helping get a motorcycle motor in the frame. Went pretty well until we had it all bolted in and he realized he forgot to install the rear drive coupler and it won't go on after the motor is in ![]() ![]() Saturday, I dropped my harness and computer off to get reworked and had lunch with my mom before I loaded my welder up and brought it back home. When I got home, the ICT accessory brackets were waiting for me so I got those installed. They are pretty slick and look like they'll work perfect! ![]() After that, I remade my transmission crossmember, this one doesn't hang under the frame at all and is pretty simple like the last one. It works great! ![]() I also cleaned up the gauge bezel that I'll be using, I'm converting from warning lights to gauges. I used aluminum colored paint and it looks pretty shiny when it's wet but it mellowed out and looks pretty good after it dried. ![]() Sunday, I was working pretty hard to find some motivation to get in the garage. I started cleaning up a bit from Saturday and doing some small tinkering. I got my electric fan setup on Saturday and mocked it up on the radiator. Northern does a great job, I'm impressed with the quality of work for sure! ![]() After that, I had a buddy swing by to check up on the progress and BS for a bit. When I put the truck throttle body on the car intake, the PCV hose barb was in the way of the throttle cable bracket. I was able to heat it up with my heat gun and rotate it down out of the way like it is on the LS1 throttle bodies. Had nothing to lose and it turned out perfect. ![]() That was about it for progress, I should have the remaining parts show up this week, maybe next weekend I can get the fuel system and harness figured out and fire this bad boy up ![]() |
Just plugging away at the old girl. I'm not really in a rush to get it done so I'm taking my time and making sure it's all done right.
The factory exhaust manifolds didn't fit like I had hoped so I picked up the Hooker exhaust manifolds and they fit way better. I have to massage the brake lines and the frame towers a little bit but I'm happy with them. ![]() ![]() Last night, I got my Bosch tachometer in the mail so I put the gauges together. The bracket from rideblue00 makes the install nice and seamless. I'm happy with how the gauges turned out! ![]() |
