Old 02-25-2017, 12:33 PM   #1
67 Burb
67 Burb's Avatar
Re: Wanting to keep the 6 bolt hub look
I installed a front disk brake kit on my 67 Burb. The kit from Classic Performance Products uses 1971 to 87 C10 components. I selected to go with the 6-bolt rotors because my rear axle is 6-bolt. The rotors I have are probably exactly the ones that you need.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 02-27-2017, 12:18 PM   #2
3+3 1Ton Dually
Thank you all! I have ordered a kit from Mcgaughys.
I'll post pics as soon as I receive them and get them installed!
Nothin' but time!
3+3 1Ton Dually is offline   Reply With Quote
Old 02-27-2017, 01:01 PM   #3
chewychevy67
Did you keep the old drum brake metal lines? Any chance you have photos of how the rubber hose looks from behind?
chewychevy67 is offline   Reply With Quote
Old 02-27-2017, 01:24 PM   #4
3+3 1Ton Dually
I'll check this Thursday when I get back home.
Nothin' but time!
Old 02-28-2017, 12:51 AM   #5
67 Burb
67 Burb's Avatar
I used the original steel brake lines, but needed adapters to fit the hose fittings.
I just noticed your location - I bought The Burb in Saskatoon.
Bob
