Old 03-06-2017, 02:21 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Complete 402 BB with th400. 1972
Just pulled from a 72 gmc 1/2 ton burb. Been sitting since 91. The engine does NOT turn over but still has oil in it. 3999290 and date looks like E 15 72. Will sell as 2 options.
Option 1 is complete as seen with the 72 only mounts and alt brackets, power steering set up and trans. smog, etc... $1000
Option 2 is a long block and trans for $400. (no accessories, intake to pan, water pump to trans is it)
No shipping and not parting out.
Located in northern MN.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-06-2017, 04:08 PM   #2
67kid
Re: Complete 402 BB with th400. 1972
if you decide to part and ship interested in smog setup
67kid is offline   Reply With Quote
Old 03-07-2017, 02:44 PM   #3
too much stuff
Roadtrip!
Will keep that in mind. I have one ahead of you on the smog stuff if I decide to split up.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-07-2017, 09:19 PM   #4
davischevy
davischevy's Avatar
I need the air cleaner and spacer, exhaust manifolds with the heat shield and tube.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-07-2017, 09:49 PM   #5
1rippen6
Do you know if the big block air cleaner is different than a small block?
1rippen6 is offline   Reply With Quote
Old 03-07-2017, 10:12 PM   #6
leddzepp
Moderator
leddzepp's Avatar
They are the same
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-07-2017, 10:22 PM   #7
1rippen6
Originally Posted by leddzepp View Post
They are the same
Do they need a spacer between the carb and air cleaner sorry for sidetracking your tread.
Old 03-07-2017, 10:42 PM   #8
davischevy
davischevy's Avatar
they use the same spacer, but the tube is different.
other Larry
Old 03-07-2017, 10:44 PM   #9
davischevy
davischevy's Avatar
I have plenty of air cleaners. I need the spacer tube, heat shield and heat pipe.
other Larry
Old 03-10-2017, 11:46 PM   #10
too much stuff
Roadtrip!
Still here, cash talks...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-16-2017, 10:22 PM   #11
too much stuff
Roadtrip!
bump...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-17-2017, 04:56 PM   #12
67kid
Originally Posted by too much stuff View Post
bump...
Still interested in smog and a/c if you separate
Old 03-26-2017, 01:30 PM   #13
too much stuff
Roadtrip!
No a/c on this one...
May consider trades for hard to find parts...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-26-2017, 01:41 PM   #14
67kid
What are you looking for?
Old 04-05-2017, 09:17 PM   #15
too much stuff
Roadtrip!
A guy showed up and had to have the engine, but nothing else would work for his application. Therefore the smog stuff is up for grabs. The pump does turn over. Still has the tower clamps on it. Randy500 asked first and 67kid can be up second. I may be away from the computer for a few days...
$300 plus shipping.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-05-2017, 09:39 PM   #16
randy500
Ok, I think I'm in can you give me 24hrs to decide and shipping quote to 98409?
Do you have the bolt with stud on the end where the adjusting bracket connects to the water pump?
I never thought about it before but I guess the ex manifolds are included since they have smog holes...
I guess 2 spark plug heat shields are missing?
randy500 is offline   Reply With Quote
Old 04-05-2017, 09:46 PM   #17
too much stuff
Roadtrip!
Think it over, as I will be gone for a few days. I don't think I pulled the stud. I had about an hour to strip it down before the guy showed up and it got dark out...
The manifolds are included... I didn't even try any of the tubes. I did soak them for a few days. Pretty much what is pictured and the pump does turn.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-10-2017, 05:02 PM   #18
too much stuff
Roadtrip!
Something you want? I will have to find a way to ship without damage. I would guess shipping around $80, but that is a guess.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-10-2017, 05:32 PM   #19
randy500
I'm interested but not with the exhaust manifolds, I have no use for those and the tubes I am sure will not come out.
I will offer $125 shipped for the pump with the attached hoses. Should fit in a large flat rate box.
Old 04-10-2017, 05:40 PM   #20
DANTIP
DANTIP's Avatar
That's a very good price for the smog parts. The water pump pulleys are different for the smog pump. Might want to see if the buyer wants them.
Dan
DANTIP is offline   Reply With Quote
Old 04-10-2017, 05:49 PM   #21
randy500
Dan
That engine in non A/C and has the standard double row water pump pulley that most have, which runs the SMOG pump. The pulley for A/C has a 3rd row pulley on the water pump which is smaller in diameter. The SMOG pump pulley sits out further too with A/C.
Old 04-10-2017, 08:57 PM   #22
too much stuff
Roadtrip!
I am going to try to sell together if possible. If they don't sell, I will think on your offer.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-10-2017, 11:42 PM   #23
67kid
I will take complete
Old 04-11-2017, 08:22 AM   #24
too much stuff
Roadtrip!
Let me see the best way to get it shipped without damage for you.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-11-2017, 11:03 AM   #25
ho70
ho70's Avatar
figures.....the engine is gone, just found out my 402 is cracked and I am finally close
ho70 is offline   Reply With Quote
