Re: Complete build change. Lifted 2wd
Yes, I did it. It depends if you bought the plate to mount the speedometer, or if you build one. I built mine, and of actual work working just on the speedometer, I think I have about 12-15 hours, trying to make everything perfect (I'm a perfectionist). If you bought the bracket, it would cut down on probably about 3 hours not having to do a little bit of trial and error to make everything fit correctly, not to mention I think the plate would make for a better finished product.
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
| Bookmarks |
| Tags |
| 2wd lift, 67-72 chevy, lifted, lifted 2wd, ls swap |
