Old 04-04-2017, 03:43 PM   #9
Devil Pup
Devil Pup's Avatar
Re: Complete build change. Lifted 2wd
Originally Posted by kehstr View Post
Yes, I did it. It depends if you bought the plate to mount the speedometer, or if you build one. I built mine, and of actual work working just on the speedometer, I think I have about 12-15 hours, trying to make everything perfect (I'm a perfectionist). If you bought the bracket, it would cut down on probably about 3 hours not having to do a little bit of trial and error to make everything fit correctly, not to mention I think the plate would make for a better finished product.
Wow that sounds like a ton of work. I did buy the plate and box from Captianfab on here so hopefully that cuts down on the install time.
Devil Pup is offline   Reply With Quote
2wd lift, 67-72 chevy, lifted, lifted 2wd, ls swap
